Calculating Force for 5.0g Object at 11000 g's
  • Thread starter Thread starter Paulbird20
    Centrifuge
The discussion revolves around calculating the force required to accelerate a 5.0g object at an acceleration of 11000 g's, specifically in the context of a centrifuge. The original poster expresses uncertainty about how to proceed without additional information such as rpm or diameter.
  • Exploratory, Assumption checking
  • Participants discuss the application of Newton's second law and the conversion of acceleration from g's to standard units. There are questions about the necessity of converting mass from grams to kilograms for the calculations.
The conversation includes attempts to clarify the correct approach to calculating force, with some participants providing insights on unit conversions and the relationship between mass and acceleration. There is acknowledgment of a misunderstanding regarding the conversion process, but no explicit consensus has been reached on the overall method.
Participants note the lack of specific parameters such as rpm or diameter, which may affect the calculation. There is also a discussion about the implications of using different units for mass and acceleration.
Paulbird20
Force required to accelerate 5.0g object at 11000 g's. (in a centrifuge)
But it does not give me rpm or diameter so how can i calculate the force?
Im assuming it really doesn't matter that its in a centrifuge? Any leads would help
Write down the equation of force using Newton 2. What is the value of the centripetal acceleration?
F= M* A
I tried converting the acceleration out of G's by dividing 11000 by 9.8 then times it by 5... Do i need to convert the mass out of grams and into KG?
Paulbird20 said:
F= M* A
A "G" is shorthand for the acceleration of gravity, 1 G is 9.8m/s^2 acceleration. You've got 11000 G's...you should be multiplying, not dividing. And yes, if you want your answer in the basic SI force unit of Newtons, mass must be expressed in kilograms.
Awsome i got it. Thank you so much phanthom jay i was dividing the 11000/ 9.8 rather than multiplying ;)
  • · Replies 35 ·
  • · Replies 18 ·
