Proving Complex Function Well Defined
The discussion revolves around proving that a complex function is well defined, particularly in the context of a continuous vector field defined on a connected domain in R². Participants explore the implications of defining functions and the conditions under which they maintain a one-to-one correspondence between domain and codomain values.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants discuss the definition of a well-defined function, questioning the implications of defining functions through integrals and the necessity of independence from the choice of paths. Some express confusion about the relationship between paths and integrals.
There is an ongoing exploration of the conditions required for the functions to be well defined. Participants have offered guidance on how to approach the proof, particularly regarding the use of independent paths and closed contours. Multiple interpretations of the problem are being examined, with no explicit consensus reached yet.
Some participants note the complexity of notation and the challenge of adhering to specific definitions provided by textbooks or instructors. There is also mention of the need to clarify the distinction between paths and integrals in the context of the discussion.
Milky
What does it mean to prove a complex function is well defined?
In general, when you hastily define a function by means other than specifying explicitly each value of the function associated with each value of the domain, it is a good idea to check that the function is well defined. That is to say, that the way you defined your function indeed defines a function, in the sense that to each value in the domain corresponds one and only one value in the codomain.
So essentially, if:
[tex](x,y)=(x_0,y-0), \phi(x,y)=\phi(x_0,y_0)[\tex] <br /> <br /> ?[/tex]
No, this is a triviality. If a=b, then always f(a)=f(b).
you want to show that if (x,y) is in the domain of the function, then there is one and only one element b in the codomain sucht that f(x,y)=b.
I've done an example in complex variables earlier, which I've repasted here. If I show you my reasoning would you be able to tell me if i proved it right?
Let D be a connected domain in R^2 and let u(x,y) be a continuous vector field defined on D. Suppose u has zero circulation and zero flux for any simple closed contour on D.
[tex]u(x,y) = (u_1(x,y),u_2(x,y))[/tex]
[tex]\Gamma = \int_{c}(u\circ\gamma)tds = 0[/tex][tex]F=\int_{c}(u\circ\gamma)nds[/tex] = 0[/tex][tex]\phi(x,y)=\int_{c}(u\circ\gamma)tds[/tex][tex]\psi(x,y)=\int_{c}(u\circ\gamma)nds[/tex]Prove that [tex]\phi, \psi[/tex] are well defined.
For [tex]\phi[/tex]:
I think to prove its well defined means to prove that if [tex](x,y)=(x_0,y_0), then \phi(x,y)=\phi(x_0,y_0)[/tex]
Let [tex]C_1[/tex] and [tex]C_2[/tex] be two independent paths from [tex](x,y) to (x_0,y_0)[/tex]
Then, these two paths form a closed contour [tex]C_0[/tex], for which the integral is zero. Then,
[tex]\int_{c_0}(u\circ\gamma)tds = 0 = \int_{c_2}(u\circ\gamma)tds - \int_{c_1}(u\circ\gamma)tds[/tex]Then, [tex]\int_{c_2}(u\circ\gamma)tds[/tex] = [tex]\int_{c_1}(u\circ\gamma)tds[/tex]So, when [tex](x,y)=(x_0,y_0)[/tex] the integrals are equal as well.
Is this how to prove it is well-defined?
Your notation for flux and circulation are too messy. And why do you invoke Cauchy when there is no mention of complex functions anywhere. The integrals over loops are simply all equal to 0 by hypothese. so, no, you did not prove anything.
This was the notation given to me by both my book and my professor. I have to work with what he wants me to work with.
Okay, I don't know where to start now. In my notes, I have that
would be well defined if the integral was independent of the choice of path.
Do you have any suggestions to start me off? Thanks.
Pick two paths and show that they give the same answer.
Essentially, I thought that's what I was doing but now I'm confused.
I have revised post 5, and what I did was
1. Created two independent paths from [tex](x,y) to (x_0,y_0)[/tex]
2. Let the two paths form a closed contour C, in which [tex]C=C_2-C_1[/tex]
3. Since the integral of a closed contour is zero, then [tex]C_1=C_2[/tex]
Since they are equal, they are independent of the path. So, it is well defined.
Where have I gone wrong?
Not always. For example, consider these attempts to define a function of rational numbers:
[tex] f\left(\frac{p}{q}\right) = \frac{p^2 + q^2}{2pq}[/tex]
[tex] f\left(\frac{p}{q}\right) = p^2 + q^2[/tex]
One of these is a function, and one is not. The one that isn't fails precisely because of an example where a=b, but [itex]f(a) \neq f(b)[/itex].
Did I do it correctly?
these are paths, subsets of R^2, what does it mean to subtract one from the other? Nothing in this case
No. The paths are not the same. But you weren't supposed to show that.
where have I gone wrong.
In confusing a path with the integral along that path - I think you have the right idea though. Pick those two paths, C_1 and C_2, jointly they form a closed path, C and the integral around the path is zero. Call the integals I(C), I(C_1) and I(C_2) in the natural way.
0=I(C)
and I(C) equals what?
I(C) would be the addition of I(C_1) and I(C_2), but since one of those integrals goes in the clockwise direction, it would be I(C_1) - I(C_2)
So, then the integrals are equal?
  • · Replies 17 ·
  • · Replies 27 ·
