Solving for Parameter a in a Piecewise Function
The discussion revolves around finding values of the parameter \( a > 0 \) for a piecewise function defined differently for positive and non-positive \( x \). The function's continuity at \( x = 0 \) is a central concern.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the limit of the function as \( x \) approaches 0, questioning the necessity of the limit being zero and discussing the continuity condition at that point. There are attempts to apply L'Hôpital's Rule and derive a quadratic equation in terms of \( \ln(a) \).
The discussion is active, with participants presenting different interpretations of the limit and its implications for the parameter \( a \). Some have derived equations to solve for \( a \), while others are questioning the assumptions made regarding the limit's value.
Participants are navigating the conditions for continuity of the piecewise function at \( x = 0 \) and are considering the implications of different limit approaches. There is an emphasis on ensuring both expressions of the piecewise function yield the same value at that point.
azatkgz
Find all values of the parameter a>0 such that the function
[tex]f(x)=\left\{\begin{array}{cc}\frac{a^x+a^{-x}-2}{x^2},x>0\\3ln(a-x)-2,x\leq0\end{array}\right[/tex]
[tex]\lim_{x\rightarrow 0}\frac{a^x+a^{-x}-2}{x^2}=0[/tex]
[tex]0=3ln(a-0)-2\rightarrow a=e^{2/3}[/tex]
Why should the limit value be 0?? :confused:
All that is required is that AT x=0, both expressions should attain the same value!
Now, consider the function's expression for the non-positives.
Clearly, its limit at x=0 is 3ln(a)-2.
Thus, you are to determine those values of "a" so that the limiting value of the function expression for the positives equals 3ln(a)-2 as well.
ok
[tex]\lim_{x\rightarrow 0}\frac{a^x+a^{-x}-2}{x^2}=\frac{ln^2a}{2}[/tex]
by L'Hopital Rule
[tex]\frac{ln^2a}{2}=3ln(a)-2[/tex]
[tex]ln^2a-4lna+4=0[/tex]
The limit of the upper expression should be [tex]\ln^{2}(a)[/tex]
Thus, you have the quadratic in ln(a) to solve:
[tex]\ln^{2}(a)=3\ln(a)-2[/tex]
  • · Replies 40 ·
