| Thread Closed |
Vector Funtions |
Share Thread |
| Oct21-07, 10:15 AM | #1 |
Vector Funtions
Each of the following paths describes the motion of a particle having the same path, namely the unit circle x^2 + y^2 =1. Although the path for each particle is the same, the behavior of each particle is different. For each particle, answer the following questions: i. ..... ii ....... iii Does the particle move counterclockwise or clockwise? iiii ......... 2. Relevant equations 3. The attempt at a solution The logic I used to answer part 3 for each particle was to check the position at t=0 and then again at t=pi/2. The change in position will tell me whether it has moved clockwise or counterclockwise. What I need help is n confirming whether or not my method is correct or whether there is some other neater way to do this question. Thank-you all for the help!! |
| Oct21-07, 12:45 PM | #2 |
?? You haven't given the formula for the motion so it is not clear whether your method works or not. It is possible that the particle is moving clockwise at t= 0, then before t= pi/2, turns and moves back counter clockwise. If the particle is moving either always counterclockwise or always clockwise, as is implied by the fact that the question does not ask about a particular time, yes, that method works. But what if it had asked which way the particle was moving at t= 0?
| Oct21-07, 08:34 PM | #3 |
It is always moving in the same direction. For instance, one of the formulas was
(Cos t)i - (Sin t)j. You raised an interesting question. What if the question asked which way is the particle moving at t=0. What method would you apply in that case? Please tell me if I am right: You find the tangent to the curve at that point and find the direction of that vector with respect to the xy-plane. Am I right? |
| Oct22-07, 05:53 AM | #4 |
Vector FuntionsYou raised an interesting question. What if the question asked which way is the particle moving at t=0. What method would you apply in that case? Please tell me if I am right: You find the tangent to the curve at that point and find the direction of that vector with respect to the xy-plane. Am I right?[/QUOTE] Yes, that would work. Another way would be to just look at one component: y= -sin(t) so y'= cos(t). At t= 0, the point is (1, 0) and y is increasing: counter-clockwise. |
| Thread Closed |
Similar discussions for: Vector Funtions
| [SOLVED] Series with Trigonometric funtions | Calculus & Beyond Homework | 1 | ||
| How to add more funtions on Ti-84 silver | Computing & Technology | 2 | ||
| Eigen Funtions | Calculus | 2 | ||
| wave funtions | Advanced Physics Homework | 3 | ||
| Trig Funtions Problems | Introductory Physics Homework | 4 | ||
