Weight on a rocket accelerating upward
The problem involves a rocket accelerating upward at 20.0 m/s² and a 105.0 kg astronaut standing on a scale, raising questions about the scale reading in kg during the launch.
  • Exploratory, Assumption checking
  • Participants discuss the application of F=ma to determine the astronaut's weight under acceleration, with one participant attempting to convert force in Newtons to weight in kilograms using various conversion factors.
Some participants have provided guidance on using the correct relationships between mass, weight, and acceleration, while others have expressed uncertainty about the calculations and assumptions made regarding the scale's calibration.
There is a mention of the scale being calibrated on the Earth's surface, which may affect the interpretation of weight during the rocket's acceleration.
Hisui
"During the launch, a rocket is accelerated with 20.0m/s^2 upward. A 105.0kg astronaut is more concerned about his weight than about his safety and is standing on a scale. What is the scale reading in kg?"
F=ma and also 4.45N=1lb
So, first I solved F=ma with the information given to get 2100N, and since I don't think that N can convert to kg with an equation, I took from the front of the book that 1kg=2.20lbs where g=9.80m/s^2, so I thought that I could figure out what 1kg was with an acceleration of 20m/s^2, and I got that 4.5lbs would equal 1kg.
I then took my previous answer of 2100N and converted it to 471.9lbs and divided by 4.51lbs, hoping to get the correct kg with the acceleration given, but I got 104.6 which seems very wrong (first, because it's almost exactly the starting weight and second, because it should be higher, not lower than the starting weight). Thoughts?
If his scale was calibrated on the Earth's surface, so that 1kg =2.2lbs, using just F=ma would yield you the correct answer.
On Earth he feels a weight of mg (105*9.8) of 1029N
When accelerating he feels a weight of ma (105*20) of 2100N
Find the ratio and multiply by his mass.
Oh, yeah I guess I was over-thinking it. Thanks!
No problem
  • · Replies 42 ·
  • · Replies 22 ·
  • · Replies 24 ·
