Related Rates: Is the Derivative of a Changing Circle's Area Constant?
  • Thread starter Thread starter rook_b
    Rate
The discussion revolves around the relationship between the changing radius of a circle and its area, specifically questioning whether the rate of change of the area (dA/dt) remains constant when the rate of change of the radius (dr/dt) is constant.
  • Participants explore the implications of a constant dr/dt on dA/dt, questioning the nature of 'r' as a function of time and its impact on the area calculation.
Some participants have provided clarifications regarding the relationship between r and time, confirming that r is indeed a function of time. The discussion includes varying interpretations of how these relationships affect the rates of change.
Participants are considering the implications of the problem statement that the radius is changing with respect to time, which introduces the need to treat r as a variable dependent on time.
rook_b
Let A be the area of a circle of radius r that is changing with respect to time. If dr/dt is constant, is dA/dt constant? Explain.
A = 2(pi)r^2
dA/dt = 2(pi)(r)*dr/dt
I can't decide. You see if dr/dt is constant and multiplied by 2(pi) then dA/dt must be constant. But, r, what is r? It must be that 'r' is a function of time, I think. Or, r is an initial value that grows as the rate dr/dt. A constant rate times a constant should yield a constant rate, but multiplied by a variable it will yield a variable rate. I hate r.
... :biggrin:
If dr/dt is any constant other than 0, yes, r is a variable and so dA/dt is a variable. Don't hate r- it's harmless.
Ah, thank you once again HallsofIvy.
Hmm, one more question. Where does time t come into this? Specifically, it seems that r must be a function of time t so is r really r(t). That is, if I wanted to graph this as time vs dA/dt. A short confirmation by anyone would be appreciated.
Yes, r is a function of t. dr/dt is the derivative of that function with respect to t. Since dr/dt does not equal 0, r(t) is not constant. We know that dr/dt does not equal 0 because the problem says that the radius of the circle is changing with respect to time.
