Impulse, I have found a, b and d
  • Thread starter Thread starter snipaj9696
    Impulse
The discussion focuses on calculating impulse and final velocities for a 3.15 kg particle subjected to a varying net force over time. The impulse of the force is determined to be 12.0 N-s, leading to a final velocity of 3.8 m/s when starting from rest. The participant struggles with calculating the final velocity when the initial velocity is -3.4 m/s, using the impulse-momentum theorem incorrectly. The average force exerted over the time interval of 0 to 5.00 seconds is calculated to be 2.4 N.
  • Understanding of impulse and momentum concepts
  • Familiarity with Newton's second law (F=ma)
  • Basic knowledge of kinematics equations
  • Ability to interpret force vs. time graphs
  • Review the impulse-momentum theorem and its applications
  • Study kinematic equations for motion with constant acceleration
  • Learn how to analyze force vs. time graphs for impulse calculations
  • Practice problems involving varying forces and their effects on velocity
Physics students, educators, and anyone interested in understanding the principles of impulse and motion dynamics.
snipaj9696
The magnitude of the net force exerted in the x direction on a 3.15 kg particle varies in time as shown in the figure below.
There is a graph that is supposed to be here. The y-axis is F(N) and the x-axis is t(s)
It starts from the orgin then goes to point (2,4), then to (3,4), then ends at (0,5). I am sorry if this looks confusing, but it wouldn't let me post the graph.
(a) Find the impulse of the force. The answer to this one is 12.0 N-s
(b) Find the final velocity the particle attains if it is originally at rest.
i m/s
(c) Find its final velocity if its original velocity is -3.4 m/s .
i m/s
(d) Find the average force exerted on the particle for the time interval between 0 and 5.00 s.
N
so far I have done..
for part A I found the answer to be 12 (4+4+4)
for part B I did I=mv which came out to v=3.8m/s
I am stuck on part c. I thought I am supposed to use I=m(vf-vi) but I keep getting a wrong answer.
And for part d I used I=f(tf-ti) and found the answer to be 2.4N
So I need part c!
F=ma; a=F/m v(f) = v(i) +at
Do that for each section.
  • · Replies 19 ·
  • · Replies 17 ·
