| Thread Closed |
9 pm, and still dont understand |
Share Thread | Thread Tools |
| Oct22-07, 09:07 PM | #1 |
A rifle bullet is fired at an angle of 30 degrees below the horizontal with an initial velocity of 800 m/s from the top of a cliff 80 m high. How far from the base of the cliff does it strike the level of ground below g=9.8 initial velocity- 800 m/s y=80 m 2. Relevant equations People i ask say.. R=(initial velocity squared x sin(2 theta) g 3. The attempt at a solution i did 800^2 x sin2(30) 9.8 i get 56556.76106-which seems way to high Then i did Soh Cah Toa Sin=Opp/Adj 56556.76106/80 and got 706.9595133 I really just dont understand what i am doing, and need help. bad. this is due tomorrow. |
| Oct22-07, 09:12 PM | #2 |
Hello welcome to Physicsforums! Hope you will learn here and also teach us what you know!
For the problem: (1)You must resolve the initial velocity into their X and Y coordinates using trigonometry. (2)Then use kinematic equations to solve the problem. |
| Oct22-07, 09:18 PM | #3 |
I dont even know any of that.
We never learned Kinematic equations. Im very slow at this, and am now regretting taking this class. |
| Oct22-07, 09:32 PM | #4 |
Hey don't despair! I can teach you what I know. I am learning this myself.
Kinematic Equations: S=Vot+0.5at^2 S=Vft-0.5at^2 S=((Vo+Vf)/2)*t Vf=Vo + at Vf^2=Vo^2 + 2aS S=Displacement in metres Vo=Initial Velocity in metres/second Vf=Final Velocity in metres/second a=acceleration in metres/second squared t=time in seconds For all kinematic problems, write your 5 variables down and write the known values in. Velocity is a vector quantity. It has magnitude and DIRECTION. direction is usually indicated by an angle as in your problem. Velocity of the bullet is 800m/s angle 30degrees below the horizontal. Draw a picture and see if you can resolve the velocity into X and Y coordinates. Have a look at this site: http://www.glenbrook.k12.il.us/gbssc...ors/u3l2c.html Then we will see if we can solve the problem. Please come back. |
| Oct22-07, 09:38 PM | #5 |
| Oct22-07, 09:46 PM | #6 |
| Oct22-07, 09:53 PM | #7 |
use the 2nd equation to find time
keep in mind the bullet is being fired DOWN, so your y value must be negative when you find time, disregard the negative value then use the 1st equation to find x |
| Thread Closed |
| Thread Tools | |
Similar Threads for: 9 pm, and still dont understand
| I dont understand this, can you help? | Introductory Physics Homework | 2 | ||
| I dont understand this | Calculus & Beyond Homework | 2 | ||
| i dont understand | Introductory Physics Homework | 1 | ||
| dont understand problem. | Introductory Physics Homework | 0 | ||
| I dont understand | Computing & Technology | 3 | ||
