Relation between Catalan numbers
  • Context: Graduate
  • Thread starter Thread starter Pere Callahan
    Numbers Relation
The forum discussion centers on proving a relation between Catalan numbers, specifically the equation C_n = \frac{1}{n+1}\left(\stackrel{2n}{n}\right) and the summation relation 1 = \sum_{l=1}^{k}{(-1)^{l-1}C_{l-1}\left(\stackrel{l+k-1}{k-l}\right)} for all natural numbers k. The user Pere successfully proved the relation using generating functions, demonstrating that the generating function of the sequence a_k equals \frac{x}{1-x}. This proof involved manipulating double summations and applying known generating function identities related to Catalan numbers.
  • Understanding of Catalan numbers and their properties
  • Familiarity with generating functions in combinatorics
  • Knowledge of binomial coefficients and their notation
  • Experience with mathematical induction techniques
  • Study the properties of Catalan numbers and their applications in combinatorial problems
  • Learn about generating functions and how to derive them for sequences
  • Explore advanced techniques in combinatorial proofs, including induction and generating function manipulation
  • Investigate the relationship between binomial coefficients and combinatorial identities
Mathematicians, combinatorialists, and students studying advanced combinatorial theory, particularly those interested in Catalan numbers and generating functions.
Pere Callahan
Hello all,
I am studying some problems in Free Probability and need to prove a relation between the Catalan numbers
[tex]C_n = \frac{1}{n+1}\left(\stackrel{2n}{n}\right)[/tex]
The relation reads:
[tex]1 = \sum_{l=1}^{k}{(-1)^{l-1}C_{l-1}\left(\stackrel{l+k-1}{k-l}\right)}\quad\quad\forall\quad 1\leq k\in\mathbb{N}[/tex]
Does anybode have an idea how to prove this? Numerically, I convinced myself that it is true for [tex]n\leq 100 000[/tex] or so:smile:
I tried induction but it didn't work out.
Thanks
Pere
Btw.: Is there a better way to display binomial coefficients...? I used \stackrel ...
well i don't have the head for this but one way you could do is write the generating function of the sum and then equating coefficients, where you should multiply the generating function of (-1)^(l-1)C_l-1 with the generating function of C(2k-l-1,l), and check any descent combinatorics book on catalan number in generating functions as to how to find the generating function of this.
sorry that i can't help you more.
Hi,
Thanks for your answer. I finally managed to prove the relation - using Generating Functions.
If we let
[tex]a_k = \sum_{l=1}^{k}{(-1)^{l-1}C_{l-1}\left(\stackrel{l+k-1}{k-l}\right)}[/tex]
we need to show
[tex]\sum_{k=1}^\infty{a_k x^k} = \frac{x}{1-x}[/tex]
because the right hand side would also be the generating function of the constant sequence [tex](\alpha_i)_{i=1}^\infty=(1)_{i=1}^\infty[/tex].
I then continued as follows:
[tex]\sum_{k=1}^\infty{a_k x^k} = \sum_{k=1}^\infty{\sum_{l=1}^{k}{(-1)^{l-1}C_{l-1}\left(\stackrel{l+k-1}{k-l}\right)}x^k}= \sum_{l=1}^\infty{\sum_{k=l}^{\infty}{(-1)^{l-1}C_{l-1}\left(\stackrel{l+k-1}{2l-1}\right)}x^k}= \sum_{l=1}^\infty{{(-1)^{l-1}C_{l-1}x^l\sum_{k=0}^{\infty}\left(\stackrel{k+2l-1}{2l-1}\right)}x^k}=\sum_{l=1}^\infty{{(-1)^{l-1}C_{l-1}\frac{x^l}{(1-x)^{2l}}}[/tex]
Where the relation
[tex]\sum_{k=0}^{\infty}\left(\stackrel{k+m}{m}\right)}x^k} = \frac{1}{(1-x)^{m+1}}[/tex]
can easiliy be shown by induction on m.
So I continued
[tex]\sum_{l=1}^\infty{{(-1)^{l-1}C_{l-1}\frac{x^l}{(1-x)^{2l}}} = \frac{x}{(1-x)^2}\sum_{l=0}^\infty{{C_{l}\left(\frac{-x}{(1-x)^{2}}\right)^l} = \frac{x}{(1-x)^2} C\left(\frac{-x}{(1-x)^{2}}\right)[/tex]
Where [tex]C(x)=\frac{1-\sqrt{1-4x}}{2x}[/tex] is the generating function of the Catalan numbers.
For [tex]-1\leq x\leq1[/tex]
We then have
[tex]\frac{x}{(1-x)^2} C\left(\frac{-x}{(1-x)^{2}}\right)=\frac{x}{(1-x)^2}\frac{1-\sqrt{1+\frac{4x}{(1-x)^{2}}}}{2\frac{-x}{(1-x)^{2}}}=\frac{\sqrt\frac{(1+x)^2}{(1-x)^2}-1}{2}=\frac{1+x-1+x}{2(1-x)}=\frac{x}{1-x}[/tex]
Looks correct to me...? Any objections?;-)
  • · Replies 16 ·
