Integration Problem: Solving \int^{0}_{-\pi}\sqrt{1-cos^{2} x} for Homework
  • Thread starter Thread starter ngkamsengpeter
    Integration
The discussion revolves around evaluating the integral \(\int^{0}_{-\pi}\sqrt{1-\cos^{2} x}\), which simplifies to integrating \(|\sin x|\) over the interval from \(-\pi\) to \(0\). Participants are exploring the implications of substituting \(\sqrt{1-\cos^{2} x}\) with \(\sin x\) and the resulting negative value obtained from the integration.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the substitution of \(\sqrt{1-\cos^{2} x}\) with \(\sin x\) and the evaluation of the integral, questioning how the negative result of \(-2\) can be reconciled with the expected positive result of \(2\). There is also a focus on the interpretation of \(|\sin x|\) in the specified interval.
Several participants have provided insights into the integration process and the interpretation of \(|\sin x|\) over the interval. There is an ongoing examination of the implications of the absolute value and how it affects the integration outcome. No consensus has been reached, but productive lines of questioning and reasoning are being explored.
Participants are working under the constraints of a definite integral and are discussing the behavior of \(\sin x\) within the interval \([-π, 0]\), noting that \(\sin x\) is negative throughout this range.
ngkamsengpeter
[tex]\int^{0}_{-\pi}\sqrt{1-cos^{2} x}[/tex]
I substitute into (sin x)^2 and get an answer of -2 but the answer should be 2 . how to i do this question.
How do you get an answer of -2? Perhaps you should show your work.
just substitute (sin x)^2 and become sqr((sin x)^2) and then become sin x and substitute the limit from -pi to 0 get -2
You need to integrate sin(x) before you plug in the limits.
I have integrate it into -cos x and plugin the limit , i got -2 .But the answer is 2 . How ?
So you have [tex]\left[-\cos(x)\right]^0_{-\pi}=cos(0)-cos(-\pi)[/tex]. Can you evaluate that?
maybe you should be interpreting [itex]\sqrt{\sin^2(x)}[/itex] as [itex]|\sin(x)|[/itex]
cristo said:
So you have [tex]\left[-\cos(x)\right]^0_{-\pi}=cos(0)-cos(-\pi)[/tex]. Can you evaluate that?[/QUOTE
[tex]\left[-\cos(x)\right]^0_{-\pi}=-cos(0)+cos(-\pi)[/tex]
shouldn't is be this way cristo.
Then , how to integrate [itex]|\sin(x)|[/itex]
For x between [itex]-\pi[/itex] and 0, sin(x)< 0. In that range, |sin(x)| is just -sin(x). Integrating that will obviously give you the negative of your previous answer.
but ((sin x)^2 )^0.5 gives us two answers
sinx and -sinx
sinx and -sinx
yeah, generally it does, but look here we are only integrating in [-pi.0], and obviously sinx, where x is from [-pi,0] is always negative, so
I sin(x) I = -sinx, whenever x is from the interval [-pi. 0]
now as halls said, integrating this you will get the desired answer.
But i use mathematica to integrate , it shows -Cot x ((Sin x)^2)^(1/2)
How to integrate to get this form ?
Why would you want to? This is a definite integral. The result is a number. The integrand reduces to |sin(x)| which, for [itex]-\pi\le x\le 0[/itex] is -sin(x). That's easy to integrate.
I've never used mathematica and what you give makes me glad I haven't! It's clearly using some general algorithm and then not recognizing that, since [itex](sin^2(x))^(1/2)[/itex] is |sin(x)|, [itex]-cot(x)(sin^2(x))^(1/2)= -(cos(x)/sin(x))(-sin(x))= cos(x)[/itex].
  • · Replies 105 ·
13K
  • · Replies 19 ·
  • · Replies 27 ·
