Springs and friction and energy, etc.
The discussion revolves around a physics problem involving a block of mass m compressed against a spring with spring constant k, which is then released to slide along a track and through a loop of radius r. The objective is to determine the compression distance x in terms of k, m, r, and gravitational acceleration g. Key equations include the spring potential energy U_{spring} = 1/2kx², kinetic energy KE = 1/2mv², and gravitational potential energy U_{grav} = mgh. The solution involves applying the conservation of energy principle, equating the spring energy to the sum of kinetic and gravitational energies at the top of the loop.
  • Understanding of conservation of energy principles in physics
  • Familiarity with spring mechanics and Hooke's Law
  • Knowledge of gravitational potential energy calculations
  • Basic algebra for solving equations
  • Study the principles of energy conservation in mechanical systems
  • Learn about Hooke's Law and its applications in spring mechanics
  • Explore gravitational potential energy and its role in motion
  • Practice solving similar physics problems involving springs and loops
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of energy conservation in action.
sadakaa
A small block of mass m is pressed up
against a spring. The spring has constant k
and is compressed a distance x. The block
slides along a track up and around a loop
of radius r and down and out on the far
side, as shown. At the top of the loop, the
loop exerts a normal force on the block
equal to the weight of the block. Neglect
friction.
Determine the compression distance, x, in terms of given quantities k, m, r and g.
U[tex]_{spring}[/tex] = 1/2kx[tex]^{2}[/tex]
KE = 1/2mv[tex]^{2}[/tex]
U[tex]_{grav}[/tex] = mgh
I started with energy conservation, but I am not sure if you just set U[tex]_{spring}[/tex] equal to the sum of KE and U[tex]_{grav}[/tex]
The picture of the problem can be seen here: http://img137.imageshack.us/img137/7804/41935428tm6.th.jpg
I'm not sure if I understood the problem. Why is the problem called Springs and FRICTION and energy?
However, I would start with the loop:
You know that in the look, the gravitational potential is equal to the energy of the block. Therefore:
[tex]E_{kin}+m\cdot g\cdot h\cdot= U_{grav}[/tex]
where h is equal to two times the radius r.
Now, you can set up another equation because you know that the energy of the block at the beginning was zero (no kinetic energy and no gravitational energy):
[tex]E_{kin}= 1/2\cdot k\cdot x^{2}[/tex]
Now, you should know how to solve the problem...
mistake on title
yea sorry about the title, it wouldn't let me edit it though. :-p
thanks for the help!
  • · Replies 37 ·
  • · Replies 58 ·
