Why Is My Calculation of Initial Velocity Incorrect in Projectile Motion?
  • Thread starter Thread starter jennypear
    Physics Projectile
The discussion revolves around a projectile motion problem where a projectile is launched at an angle and from a height, with the goal of determining the initial velocity based on its final speed upon hitting the ground.
  • Mixed
  • The original poster attempts to apply kinematic equations to find the initial velocity but questions the validity of their answer. Some participants seek clarification on the definition of initial velocity (Vo) and its role in the problem. Others raise concerns about assumptions regarding the angle of impact and the trajectory of the projectile.
Participants are exploring different interpretations of the problem, particularly regarding the assumptions made about the angle of impact and the application of energy conservation principles. Some guidance has been offered, but there is no explicit consensus on the correct approach.
There are discussions about the assumptions that may or may not be valid in the context of projectile motion, particularly regarding the angle at which the projectile strikes the ground and the application of energy conservation.
jennypear
projectile is fired w/an angle of 28.0degrees above the horizontal and from height 46.0m agove the ground. the projectile strikes ground w/a speed of 1.95xVo. Find Vo
I started using the eqution
(Vfy)^2=(Voy)^2+2*Ay*(delta Y)
Voy=Vosin(theta)=.47Vo
Vfy=1.954*Vosin(theta)=.92Vo
(.92Vo)^2=(.47Vo)^2+(2*-9.8*-46)
Vo=37.9
but my answer is wrong and I can't think of another way to answer the problem...Any ideas?
Thanks for your time!
What is Vo? Is it the velocity of projection, or, is it just a constant?
There's no guarantee that the projectile hits the ground at the same angle as it was launched!
cookiemonster
However, for this problem, I think we should assume that the projectile hits the ground at the same angle as it was launched...
Sridhar
Why should that be assumed?
cookiemonster
Not only are you not supposed to make that assumption, it is wrong! The projectile is traveling in a parabola...
You need to use the conservation of energy equation:
[tex]0 = \Delta E_m = \Delta E_p + \Delta E_k[/tex]
[tex]0 = mg(0 - h) + \frac{1}{2}m(v_f^2 - v_0^2)[/tex]
[tex]2gh = (1.95v_0)^2 - v_0^2 = 2.8025v_0^2[/tex]
The initial velocity is 17.94m/s (for g = 9.8m/s2).
Thanks for the help!
