How Do You Calculate Spring Stretch When Kinetic and Potential Energy Are Equal?
  • Thread starter Thread starter quickclick330
    Spring
The discussion revolves around calculating the stretch of a spring in a mass-spring system when the kinetic energy of the mass equals the potential energy stored in the spring. The context involves a mass sliding on a frictionless table, with the spring oscillating and an amplitude of 4 cm defined.
  • Participants explore the relationship between kinetic and potential energy, questioning how to incorporate amplitude into their calculations. They discuss the total energy of the system and its expression in terms of amplitude, as well as the conditions under which kinetic and potential energy are equal.
Participants are actively engaging with the problem, offering hints and clarifications. There is a productive exploration of the energy equations, with some participants suggesting ways to express total energy and potential energy in terms of the amplitude. Multiple interpretations of the energy distribution are being considered.
There is an ongoing discussion about the definitions of potential and kinetic energy at specific instances, and how to relate these to the amplitude of the oscillation. Participants are navigating the constraints of the problem without reaching a definitive conclusion.
quickclick330
One end of a massless spring is fixed and the other end is attatched to a mass. The mass slides on a horizontal frictionless table. The spring is parallel to the table. The mass-spring system oscillates with an amplitude of 4 cm. What is the magnitude of stretch of the spring when the kinetic energy of the mass is equal to the spring potential energy at that instant? (The spring ptotential is defined to be zero when at its relaxed length.)
I have:
KE = U
1/2*m*v^2 = 1/2ksX^s
My question is, how do I use the amplitude for this equation to work?? thanks! :-)
Hint: The total energy at any point equals the sum of KE + PE.
I know i need to use one instance of time to solve for this instant in time for energy, but I'm unsure about which points to choose?
What's the total energy expressed in terms of the amplitude?
TE = U + KE
= 1/2ksX^2 + 1/2mv^2
when the amplitude = 4, then velocity = 0?
= 1/2*ks4^2 + 0
E = 8ks ?
Good. You're on the right track. Rather than use numbers, let's just call the amplitude A:
E = 1/2kA^2.
So, at the point where KE = PE, how much are each in terms of the total energy?
i think I'm confused. I keep wanting to use PE as 1/2kA^2 and KE 1/2mv^2 but that doesn't really help me much?
The PE at any point is 1/2kX^2. At the point we want, how much of the total energy is PE? Write that as an equation.
Since total energy = PE + KE
and PE =KE
so that means that TE has to equal 2*PE
E = 2(1/2kA^2)
is this right?
and PE =KE
Yes!
E = 2(1/2kA^2)
Almost. The left side (E) is the total energy, so plug in the total energy in terms of A. On the right hand side, write the PE in terms of X. (Then just solve for X.)
ahh. that makes sense. thanks for your help!
  • · Replies 20 ·
