Solve Point P Coordinates Using Newton's Method
The problem involves finding the coordinates of point P where the tangent line to the function y=cos(x) intersects the origin. The original poster indicates that the intersection occurs around pi.
  • Exploratory, Assumption checking
  • Participants discuss the application of Newton's method and question the choice of initial guesses. There are attempts to derive the correct function for Newton's method based on the relationship between the tangent line and the cosine function.
There is an ongoing exploration of different functions to apply Newton's method to, with some participants suggesting alternative initial guesses and questioning the setup of the problem. Guidance has been offered regarding the correct function to find the zero of, but no consensus on a solution has been reached.
Participants note the importance of the tangent line passing through the origin and the need to derive the correct equation for Newton's method based on the intersection of the tangent line and the cosine function.
physstudent1
Find the coordinates to two decimal places of the point P in Figure 9 where the tangent line to y=cosx passes through the origin.
the image is the graph of y=cosx P intersects the graph at around pi.
I don't know how to attempt this, I just know I have to use Newton's method somehow I tired doing x-(f(x))/(f'(x)) but then I have a divide by zero error I'm not sure what to do.
anyone?
Try a guess that isn't x=0.
I guessed 2pi/3 and Newton's method converged onto 1.5708 = x I'm not sure if this is correct
Sounds like you did Newton's method on the wrong function. Think more carefully about the function you wish to find the zero of. You are given two points: (0,0) and (P,cos(P)) and a slope -sin(P). The line is of the form f(X)=-sin(P)*x, and the curve is of the form y=cos(x), and you want the curves to meet at X=P. How can you turn this information into something solvable by Newton's Method?
Also, be careful about your initial guess. If you choose it badly, you will converge to the wrong zero. I'm not sure your current guess will find you the right P.
I second jhicks. What function are you attempting to apply Newton's method to?
would it work to try to solve it by doing
cos(x)+sin(x)x =0
for the function I try to use Newton's method for?
You have to make the tangent line pass through the origin. Applying Newton's method to y=cos(x) yields the point at which cos(x)=0, which is not what you want.
would 3pi/4 be a better guess for the zero on the graph they look lke they meet around the miniumum of the graph and one cycle takes 2pi so this would be around pi wouldn't it?
cos(x)+sin(x)x =0
That's correct, but it looks like you are guessing that this is the correct equation rather than deriving this.
no its not a guess even though it may seem it I got it because the point I'm trying to find is where the two functions intersect which would be where they're equal cos(x)=-sin(p)x so then I put it into a form where I could find a zero cos(x)+sin(p)x then using information that jhick's supplied that I did not realize at the point of intersection P will = X
Does this initial guess converge to a value, and if so, does this value satisfy the original problem? If so, you have a solution.
So don't phrase it as a guess. This reasoning is good.
sorry, didn't mean to so for Newton's method my setup is
cos(x)+sin(x)x-(cos(x)+sin(x)x)/(-sin(x)+cos(x)x+sin(x))
If [itex]x_n[/itex] is the nth estimate of x, then the next estimate by Newton's method is
[tex]x_{n+1} = x_n - f(x_n)/f'(x_n)[/tex]
You're setup is equivalent to
[tex]x_{n+1} = f(x_n) - f(x_n)/f'(x_n)[/tex]
which is not the same as Newton's method.
ah i see my mistake now thanks I began with an initial guess of Pi and it stopped at around 2.7986
9K
