Calculating the Temperature Needed to Move a Piston in a Sealed Cylinder
The discussion focuses on calculating the temperature required to move a piston in a sealed cylinder using principles of thermodynamics and fluid mechanics. The user is attempting to determine the necessary air pressure to lift a piston weighing 0.5 kg in a cylinder with specific dimensions (diameter 3.5 cm, height 10 cm). The calculations reveal that the pressure must exceed 3823.62 Pa, leading to a temperature requirement of approximately 299 K when accounting for atmospheric pressure. The user seeks clarification on the relationship between pressure, temperature, and the forces acting on the piston.
  • Understanding of basic physics concepts, particularly force and pressure calculations.
  • Familiarity with the Ideal Gas Law and its application in thermodynamics.
  • Knowledge of units of measurement, specifically Pascal (Pa) and Kelvin (K).
  • Basic understanding of fluid mechanics, particularly in relation to piston systems.
  • Study the Ideal Gas Law and its implications for pressure and temperature relationships.
  • Learn about the concept of atmospheric pressure and its effects on fluid systems.
  • Explore the principles of thermodynamics, particularly the relationship between heat and work in piston systems.
  • Investigate the calculations involved in determining force exerted by gases in confined spaces.
Students and enthusiasts in physics, engineering, or anyone interested in understanding the mechanics of piston systems and thermodynamic principles.
npau8648
Hey all, I'm trying to do some math related to air pressure and temperature and i keep getting unreasonable answers.
What i have is a cylinder (topless, diameter 3.5cm and height 10cm) with a piston placed inside it (diameter approx 3.5cm height 4 cm). Piston weights around .5kg. Piston is currently hanging around 3cm from the bottom of the cylinder and cylinder is air sealed by a balloon. - (Trying to to an experiment kinda like a sterling engine)
Wat I am trying to do is heat up the bottom of the can, in turn heating up the air in the bottom of the can. This increase in air temp should increase the pressure (i think). F = pA, where A is the surface area of the bottom of the piston.
So wat I am trying to do is find wat temperature the air will need to be heated to before the piston will be moved up.
So I've gone:
pA > mg (The force exerted by the pressure must be greater than the weight force of the piston)
so,
p > (1.5*9.81)/(PI*.035^2)
p > 3823,62 Pa
Which already sounds a lil wrong to me.
So i keep going anyway.
Using the equation of state ( i think that's wat its called ):
P = rRT (r = rho)
R = 287
Therfore, rRT > 3823,62
T > 3823.62/(rR)
For r i used the standard density of air at sea level - 1.229 kg/m^3
so T > 3823.62/(1.229 * 287)
T > 10 K
Which really just can't be right lol I have no idea what I am doing wrong. I don't do physics or any science infact, I've tried gathering this information from various sites today, so my mistake or misunderstanding is probably obvious.
Any help would be greatly appreciated :)
Science news on Phys.org
You just figured on how much more pressure you need to lift the piston. That's extra pressure above atmospheric pressure. So what does that tell you about that 10K...?
So standard air temp at sea level is approx 288K, so add 10K. So 299K is needed.
Dont want to be a pain, but i don't exactly understand how i only calculated "extra pressure above atmospheric pressure". Would i be right in saying atmospheric pressure is acting on both ends of my piston (101300 Pa) and hence i should have:
pA (Total force exerted by pressure in bottom of can) > mg + 101300(A)
Just making sure i have the right idea.
Thanks for your quick reply btw!
  • · Replies 0 ·
  • · Replies 29 ·
