Solve the Tricky Series Question: Express \sum n^2x^n as a Function of x
  • Context: Graduate
  • Thread starter Thread starter Zythyr
    Series
The discussion revolves around the series \(\sum n^2 x^n\) and the challenge of expressing it as a function of \(x\). Participants explore various approaches to derive a closed form for the series, considering its convergence properties and mathematical manipulations.
  • One participant expresses difficulty in approaching the problem and seeks help in expressing the series as a function of \(x\).
  • Another participant humorously questions the professor's ability to solve the problem, indicating a light-hearted tone in the discussion.
  • Several participants note that the series converges only for \(|x| < 1\), emphasizing the importance of this condition in their discussions.
  • A participant mentions that there is no closed form for the series unless specific conditions on \(x\) are met.
  • One participant provides a hint suggesting that the solution involves the quotient of a quadratic polynomial and a cubic polynomial, referencing identities from external sources.
  • Another participant outlines a method involving differentiation of a geometric series to derive the function representation of the series.
  • Questions are raised about the necessity of knowing the equivalence between the series and the quotient of polynomials, indicating a search for understanding the underlying principles.
Participants generally agree on the convergence condition of the series, but there are multiple competing views on how to express the series as a function of \(x\). The discussion remains unresolved regarding the exact form of the function.
Some participants reference identities and methods that may require further manipulation or understanding of series convergence, indicating that the discussion is contingent on these mathematical steps.
Zythyr
My professor was going over some powers relating to series, and power series. He came across the problem below which he didn't even know how to solve. I am trying to figure out how to solve it, but can't get anywhere. Does anyone know how to approach this problem? Express this series as a function of x.
[tex]\sum n^2x^n[/tex] from n=1 to [tex]\infty[/tex]
So, f(x) = ?
come on. who's your professor, george w bush?
I've blanked once or twice when teaching a class before. Its embarrasing, particularly when its easy, but I've seen it happen to field medal winners
Woops sorry guys. I forgot to post the actually question. The guestion is to express that series as a function of x.
Quite simple really, [tex]f(x) = \sum_{n=1}^{\infty} n^2 x^n[/tex].
Looking for a nicer (ie closed form) answer? There is no such closed form answer, unless you are looking for values of x where [itex]|x| <1[/itex], in which case there may be.
It's not just that there is no "closed form answer"- that series only converges for |x|< 1.
I am not looking for the radius of convergence. I am looking how to epxress that series as a function.
I was alluding to that point =]
I am not looking for the radius of convergence. I am looking how to express that series as a function.
Don't you like my answer?
Just to see if the summation converges to a single function, I Maple-ed it, and Maple gives a solution to [tex]f(x)=\sum_{n=1}^{\infty} n^2 x^n[/tex]. HINT: It is the quotient of a quadratic polynomial and a cubic polynomial.
Perhaps this identity can be of some help (from Wikipedia):
[tex]\sum_{i=0}^n i^2 x^i = \frac{x}{(1-x)^3} (1+x-(n+1)^2x^n+(2n^2+2n-1)x^{n+1}-n^2x^{n+2})[/tex].
This simpler identity helps too (from here):
[tex]\sum_{i=0}^\infty i^2 x^i = \frac{x^2+x}{(1-x)^3}[/tex]
EDIT: Do a little manipulation to the above identity, and you'll end up with your solution.
My word,
1 + x + x^2 + x^3 + .. . + x^n + ... = (1-x)^(-1)
differentiating and multiplying both sides by x we have,
1+ 2x^2 + 3x^3 + ... + nx^n + ... = x (1-x)^(-2)
do the same again and you'll have a result valid inside the unit disc with the origin as a centre.
Can one go backwards from the series to the quotient of polynomials? Or must one have to know that each are equivalent from experience?
Here's how to derive it:
[tex]f(x)=x\sum_{i=1}^{\infty}n^{2}x^{n-1}=x\frac{d}{dx}\sum_{i=1}^{\infty}nx^{n}=x\frac{d}{dx}x\frac{d}{dx}\sum_{i=1}^{\infty}x^{n}=x\frac{d}{dx}x\frac{d}{dx}\frac{x}{1-x}[/tex]
Now, do the differentiations, and get the rational representation of f(x).
Well we need an infinite series, S satisfying the following relation,
S = 1 + xS
Not all that far off, it can be more 'traditionally' derived by considering the finite geometric progression and evaluating the limit. I've provided a simple derivation that can be easily followed.
  • · Replies 33 ·
