Cost-effective design for fencing and partitioning a rectangular ranch field?
The discussion revolves around two related homework problems involving the design of fencing for rectangular ranch fields. The first problem focuses on minimizing the length of fence needed for an area of 1,900,000 square feet, while the second problem aims to minimize the cost of fencing an area of 460 square feet, including a partition. Both problems require consideration of dimensions and cost factors associated with different fencing materials.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss setting up equations relating dimensions to area and cost. There are attempts to derive functions for total length and cost based on dimensions. Questions arise regarding the interpretation of variables and the relationship between dimensions.
Some participants have made progress in deriving equations and finding critical points for minimization. However, there is uncertainty about the implications of the derived values and how they relate to the overall problem context. Clarifications regarding the relationships between dimensions are being explored.
Participants are working under the constraints of specific area requirements and cost per foot of fencing material. There is a need to clarify the definitions of variables used in the equations, particularly in relation to the costs involved.
mayo2kett
hi i have two homework assignment I'm kinda stuck on they are very similar i was hoping someone could help me...
1) A rancher wants to fence in an area of 1,900,000 square feet in a rectangular field and then divide it in half with a fence down the middle parallel to one side. What is the shortest length of fence that the rancher can use?
2) A rancher wants to fence in an area of 460 square feet in a rectangular field using fencing material costing 1.5 dollars per foot, and then divide it in half down the middle with a partition, parallel to one side, constructed from material costing 0.4 dollars per foot.
Assuming that the partition is parallel to the side which gives the width of the field, find the dimensions of the field of the cheapest design.
Length=
Width=
What is the (total) cost of the cheapest design?
1) Let A be one side of the rectangular fence and B be the other side. Since the area of the fence must be 1,900,000 square feet, we can relate A and B like this:
B = 1,900,000/A
Now write down the function for the total length of the fence:
f(A) = 3A + 2B = 3A + 3,800,000/A
Find the derivative of that function, see where it has a minimum and find the value of the function in that minimum point.
2) Very similar problem. Again we will use W for width and L for length and relate them like so:
L = 360/W
The function for the total cost of the fence is:
f(W) = 2*1.5*W + 2*1.5*L + 0.4*W = 3.4W + 1080/W
Again find the derivative of that function, see where it has a minimum and find the value of the function in that minimum point.
for question one i did:
f(A)'=3-(3800000/A^2)
A=1125.46
is this shortest side? i wasn't sure where to go from here
for the second question i have:
f(w)'=3.04-(1380/w^2)
and w=21.306
so then i put the 21.306 into the original equation l=460/w=460/21.306=21.590
at this point I'm not sure what the l and the w stand for, are they the length or the sides of the fence or are they the cost of each side since we added in the cost of the different types of fencing??
1) You found A, how does it relate to B? Find B and see which of them is smaller.
2) L and W represent the length of the width and length of our fence. The cost was added in the f(W) function (the $1.5, $1.5 and $0.4 coefficient).
