| Thread Closed |
calculating normal force and net force of 20 kg mass going down inclined plane at... |
Share Thread | Thread Tools |
| Oct24-07, 02:39 PM | #1 |
angles of 30, 45, 60. calculate weight of block, the normal force, and net force for each angle separately. 2. Relevant equations normal force m*g*sin theta net force m*g*cos theta 3. The attempt at a solution weight of block is just 20 kg, right? and so for 30 degrees: normal force= 20 kg* 9.81 m/s/s * sin 30, right? and net force=20 kg * 9.81 m/s/s * cos 30... |
| Oct24-07, 02:50 PM | #2 |
No. The weight of an object is measured in lbs or N. kg is a unit of mass.
Weight in Newtons = mass in kg*acceleration due to gravity in m/s^2. Draw a diagram showing all your forces. |
| Oct24-07, 02:52 PM | #3 |
wait....my next question then asks how does each force value change as the angle changes and why?
in this case, wouldn't the weight be constant...? |
| Oct24-07, 02:54 PM | #4 |
You're absolutely right. (weight is constant). Your calculations are not, however, correct.
| Oct24-07, 02:57 PM | #5 |
ok, then can you please tell me what i did wrong and how to calculate them correctly?
thanks. |
| Oct24-07, 03:04 PM | #6 |
Start with a diagram and label your forces, you will see physically how to apply the trig functions.
http://www.cheops-pyramide.ch/khufu-...ined-plane.gif here is a good diagram |
| Oct24-07, 03:13 PM | #7 |
ugh. i'm still confused.
| Oct24-07, 03:25 PM | #8 |
Gm is the weight, N is the normal force. the Alpha sign is the angle. The same angle of the incline. Do you see that a triangle has formed? You can apply the trig functions of sine and cosine.
| Oct24-07, 03:31 PM | #9 |
so normal force= 196.2 N * cosine 30=170N, which is what I had,
and net force= 196.2 N *sin 30=98.1 ? |
| Oct24-07, 03:45 PM | #10 |
is that correct?
| Oct24-07, 04:22 PM | #11 |
You had normal force = 196.2sin30 which is not correct.
Now your calculations look correct. If there was friction then the net force would be the force going down the incline subtracted from the friction force(going up the incline). But everything looks good! great job! |
| Oct24-07, 05:11 PM | #12 |
right, i did have it like that and just now after i looked at my notes, i realized i accidently switched the two formulas.
thanks for your help. i really appreciate it! |
| Thread Closed |
| Thread Tools | |
Similar Threads for: calculating normal force and net force of 20 kg mass going down inclined plane at...
| Normal Force Inclined plane | General Physics | 5 | ||
| The Normal Force and Inclined Planes | Introductory Physics Homework | 6 | ||
| Normal force on an inclined plane | Introductory Physics Homework | 2 | ||
| Normal force on inclined planes. | Introductory Physics Homework | 12 | ||
| Inclined plane force problem | General Physics | 0 | ||
