Two objects - when do they meet?
  • Thread starter Thread starter dvdqnoc
The problem involves two objects: one thrown downward from a height of 99 m with an initial speed of 4 m/s, and another propelled upward from ground level with a speed of 25 m/s. The objective is to determine the height at which the two objects meet, considering the acceleration due to gravity.
  • Mixed
  • The original poster attempts to derive position equations for both objects and set them equal to find the meeting point. Some participants question the assumption of constant velocity and suggest incorporating gravitational acceleration into the equations.
Participants are exploring different interpretations of the problem, particularly regarding the effects of gravity on the motion of both objects. Some guidance has been offered regarding the appropriate equations to use, but there is no explicit consensus on the next steps.
There is a noted concern about the original poster's approach, as it does not account for the changing velocities of the objects due to gravitational acceleration. The discussion reflects a mix of attempts to assist while maintaining a focus on encouraging independent problem-solving.
dvdqnoc
An object is thrown downward with an initial
speed of 4 m/s from a height of 99 m above the
ground. At the same instant, a second object
is propelled vertically from ground level with
a speed of 25 m/s.
The acceleration of gravity is 9.8 m/s^2.
At what height above the ground will the
two objects pass each other? Answer in units
of m.
None - I believe you make your own equation.
Look below to see what I mean.
Well I tried to find the position equation of both
objects, then set them equal to each other to
find the time at which their positions are equal.
For the top object, since at time 0 his position
is 99 m, and his initial velocity is 4 m/s, I found
its position equation to be x(t) = -4t + 99. The
-4t is negative because its traveling down.
For the bottom object, since at the time 0 his
position is also 0, it has no constant. His initial
velocity is 25 m/s, so I got his position equation
to be x(t) = 25t. The 25 t is positive because he
is propelled upwards.
So I set the two equations equal, and solved for t:
-4t + 99 = 25t
99 = 29t
t = 3.4138
I plugged this time into one of my position
equations to find the position when they
meet:
x(t) = 25t
x(3.4138) = 25(3.4138)
x = 85.3448 m
This answer seemed to make sense, because
since the bottom object is propelled significantly
faster than the top object, they should meet
somewhere close to the 99 m mark.
But low and behold, 85.3448 m is incorrect.
Help!
You quoted a figure for the acceleration of gravity but your equations are all assuming constant velocity. Put g into the problem.
Don't forget, your "top" and "bottom" objects won't stay at [itex]4ms^{-1}[/itex] & [itex]25ms^{-1}[/itex] forever, they experience gravity. I suggest you look at this equation for a free-fall object:
[tex]x(t) = x_0 + ut - \frac{1}{2}gt^2[/tex] See if you can apply this to the problem
Do you think I'm giving too much help :confused:
Solving the problem for them is too much. Beyond that, how explicit with hints you want to be is completely up to you.
  • · Replies 38 ·
