Work-Kinetic Energy Homework: Solving for Force, Work & Kinetic Energy
  • Thread starter Thread starter BuBbLeS01
    Energy
The problem involves a 1540 kg car that decelerates from a speed of 94.0 km/hr, focusing on calculating the work done by the braking force and the change in kinetic energy of the car.
  • Participants discuss converting speed from km/hr to m/s to simplify calculations and apply the kinetic energy formula. There is uncertainty regarding the sign of the work done and whether to report it as negative or positive.
Some participants have provided calculations for kinetic energy and work, while others are questioning the correctness of their results and the appropriate sign for the work done. There is a mix of interpretations regarding the final answers.
Participants mention potential rounding issues in calculations and the convention of reporting work as a magnitude versus including the sign. There is also a reference to the problem being marked incorrect despite the calculations presented.
BuBbLeS01
With brakes fully applied, a 1540 kg car decelerates from a speed of 94.0 km/hr. What is the work done by the braking force in bringing the car to a stop? What is the change in the kinetic energy of the car?
W = -Fd
Not sure how to start this problem?
This problem is, I think, most easily solved by finding the initial kinetic energy of the car.
Calculations are simplified if you convert 94.0 km/hr to m/s ==> 94.0 km/hr ~ 26.111111 m/s.
Now, K = 1/2 m v^2 , so the initial kinetic energy of the car is given by K = (1/2)x(1540 kg)x(26.111111 m/s)^2 = approx. 525 kJ.
Since the final velocity of the car is zero, the final kinetic energy is zero as well. Thus, the change in kinetic energy is 0 - 525 kJ = -525 kJ.
The work is equal to the total change in energy, so W = -525 kJ as well.
===> change in KE = W = -525 kJ <===
I understand...but its saying its incorrect?
well, i may have rounded a bit too much... also, it's common just to write the magnitude of the work, so try W = 525 kJ if -525 kJ doesn't work. A more exact answer is 524978.3951 J
I got the change in kinetic energy right but, is the work is wrong when entered as positive. So do I enter is negative?
yeah, negative was my first suggestion... in my original post i had it as positive but then edited it shortly thereafter to be negative... just a typo.
Oh ok...that was right then, thank you much!
  • · Replies 17 ·
  • · Replies 58 ·
  • · Replies 16 ·
