Looking for help with antideratives
  • Thread starter Thread starter fk378
The problem involves finding a function \( f \) such that its derivative \( f'(x) = x^3 \) and that a specific line \( x + y = 0 \) is tangent to the graph of \( f \). This falls within the subject area of calculus, specifically focusing on antiderivatives and tangent lines.
  • Participants discuss the relationship between the function and its derivative, exploring the implications of the tangent line's slope and the conditions for tangency. Questions arise regarding the correct interpretation of the tangent line and how to determine the constant \( C \) in the antiderivative.
The discussion has progressed through various interpretations and clarifications regarding the tangent line and the function's behavior at specific points. Participants have offered guidance on how to relate the values of the functions and their derivatives at the tangent point, leading to a clearer understanding of the problem's requirements.
There is some confusion regarding the application of the tangent line's slope and the values of the functions at the point of tangency. Participants are also navigating through assumptions about the nature of the functions involved and the implications of their derivatives.
fk378
Find a function f such that f'(x)=x^3 and the line x+y=0 is tangent to the graph of f.
antiderative
f(x)=(x^4)/4 + C
I don't know where to go from here... the tangent line equation is a way to find the slope, no? So rearranging x+y=0 gives y=x which means that the slope is 1...but wait, doesn't y=x mean that the tangent is a straight line, so therefore the derivative is 0? As you can tell, I'm very confused!
think more about y=x being a straight line, compare this to something such as y=5, still think its straight? you also have a sign error when rearranging the tangent line equation.
Oh I see...thanks =)
so y=-x
therefore slope= -1
I have the equation of the function. Now is the next step just to see what C must equal in order for the slope to be -1?
You have two functions, the straight line f(x)=-x and the curve g(x)=x^4/4+C. At some value of x (let's call it x=a), the line is tangent to the curve.
What does this tell you about the values of f(a) and g(a)?
What does it tell you about the values of f'(a) and g'(a)?
The value a in f(a) can be substituted into g(a) and the value of a in f'(a) can be substituted into g'(a)??
Ok, you've got the slope is -1. Where is f'(x)=(-1)?
x^3=-1
so x=-1
Good. Now at the tangent point (x=-1) y=f(x) has to touch the curve y=-x. Can you determine C in your antiderivative?
f(x)=(x^4)/4 + C
f(-1)=1/4 + C
So since y=-x touches (x^4)/4 + C...and x=-1, then y=1
1=(1/4) + C
C=3/4
So f(x)=(x^4)/4 + 3/4 ?
You don't have to ask me if it's right. (It is). If it's slope is -1 and it's value is 1 at x=-1, then you surely are correct. Check it again.
Hold on, I'm kind of confused as to why I plug in x=-1 in the antiderivative. I found x=-1 in the derivative form, so why am I plugging it into the antiderivative? What am I looking for there?
The antiderivative is your function y=f(x). The derivative f'(x) is the slope of your function. At the tangent point to a line f(x) should equal the value of the line and f'(x) should equal the slope of the line.
Essentially the solution is composed of knowing two things about tangents to curves.
1) The tangent line and the curve share a single common point.
2) The slope of the tangent line and the curve are equivalent at that point.
So after obtaining the antiderivative with some constant C, you seek to determine what value of C you need. Well, you can solve for what value of x the slopes are the same at, and you know what the tangent line equation is, so you can solve y. Looking at (1) and (2) then, we've found the point at which (2) is true for the line and the curve.
Now all that remained for you to do was plug in that y and x value into the antiderivative, since the antiderivative and the tangent line have to share this common point (see (1)). You then found your value of C, and thus found the curve that fulfilled the above two conditions, and thus solved the problem.
