Calculating Work Done by Gravity on Thrown Ball
The discussion revolves around calculating the work done by gravity on a ball thrown vertically upward from a height of 2.07 m with an initial speed of 7.6 m/s until it hits the ground. Participants explore concepts related to energy, work, and gravitational force in the context of this motion.
  • Participants discuss the initial and final energy states of the ball, questioning how to relate these to the work done by gravity. There are attempts to apply energy conservation principles and the relationship between work, force, and displacement. Some participants express confusion about the work done when the ball is above the initial height.
The discussion is active, with participants providing insights into energy changes and the relationship between kinetic and gravitational potential energy. Some guidance has been offered regarding the overall change in kinetic energy and its relation to work done, but no consensus has been reached on all aspects of the problem.
There is a noted confusion regarding the work done by gravity when the ball is above its initial height, and participants are questioning the assumptions related to energy changes during the ball's motion.
BuBbLeS01
A 0.113-kg ball is thrown straight up from 2.07 m above the ground. It's initial vertical speed is 7.6 m/s. A short time later, it hits the ground. Calculate the total work done by the force of gravity during that time.
can I use...
1/2mv^2 = mgh
1/2v^2 - gh = W
Think of the problem like this:
What is the initial energy of the ball? (When it is thrown)
What is the final energy of the ball? (When it lands)
If you know those two quantities, you should be able to find the work.
Work done = Force x Displacement. What is gravitational force acting on the ball? What is the displacement (not distance travelled) between the initial position and final positions of the ball?
W=Fd
gravitational force = g
displacement = 2.07m
Okay so I am not understanding this problem. Apparently from 2.07m and above there is no work done but I don't know why?? And I get...
W = Fd
Ug = mgh
K = 1/2mv^2
Wtot = mgh = 2.29J
I was trying to do W = Change in K + change in Ug...why is this not the case?
The total work done on the ball is given by the ball's overall change in kinetic energy. When the ball goes up from its initial height, and reaches the top of its path, its kinetic energy has decreased. When it comes down from the top and back to that same initial height, its kinetic energy has increased. The decrease and increase in kinetic energy will add to zero, because we're ignoring air resistance. You want to find the change in the ball's kineteic energy from 2.07m to the ground. Does that help?
Oh okay...thank you that makes sense!
  • · Replies 29 ·
11K
  • · Replies 19 ·
  • · Replies 38 ·
