Resonance (Differential Equations Class)
  • Thread starter Thread starter dashkin111
    Class Resonance
The discussion revolves around a problem related to resonance in a differential equations context, specifically involving a front-loading washing machine mounted on a rubber pad that behaves like a spring. The problem requires determining the speed at which resonance vibrations occur based on the machine's weight and the force exerted by its rotor.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss setting up the problem using force equations and relate the system's parameters to the concept of resonance. There are attempts to calculate the angular frequency (omega) and convert it to revolutions per minute (RPM). Questions arise regarding the values used in calculations and the accuracy of results.
Some participants are recalculating values and questioning the accuracy of previous calculations. There is a recognition of mistakes in the input values used for calculations, and one participant has identified a specific error related to the conversion of units. The discussion is ongoing, with participants exploring different aspects of the problem.
Participants are working within the constraints of the problem statement and are addressing potential issues with precision in calculations. The original poster's calculations and assumptions are under scrutiny, and there is a focus on ensuring correct values are used in the mathematical setup.
dashkin111
[SOLVED] Resonance (Differential Equations Class)
A front-loading washing machine is mounted on a thick rubber pad that acts like a spring; the weight W = mg (with g = 9.8 m/s^2) of the machine depresses the pad exactly 0.38 cm. When its rotor spins at \omega radians per second, the rotor exerts a vertical force
F_0 cos(omega t)
Newtons on the machine. Neglecting friction, determine at what speed (in revolutions per minute) resonance vibrations will occur?
I decided to just set it up like a force equation in physics.
[tex] F=ma[/tex]
[tex] kx=mg[/tex]
Now solve for [tex]\omega[/tex] which is [tex]\sqrt{\frac{k}{m}}[/tex]
[tex]\frac{k}{m}=\frac{g}{x}=\omega^{2}[/tex]
So omega is:
[tex]\frac{35\sqrt{10}}{2}[/tex]
Transform to rpms
[tex]RPMS = \omega \frac{(60)}{2\pi}[/tex]
Which to the nearest RPM is 528. But this is wrong. Any clues?
Try to recalculate omega, or better give the values you used to find omega.
Yes, I'm confused as to where you got these numbers. Doing the same calculations I don't get the same result...
dashkin111 said:
So omega is:
Transform to rpms
My suspicion is insufficient precision, for one thing. Also, where did 35/2 come from?
Okay, found my mistake and I'll also show more steps now too.
So from the part:
[tex]\frac{k}{m}=\frac{g}{x}[/tex]
k/m is omega squared. G is given as 9.8 m/s^2 and x is given as .38 cm, or .0038 m.
Solving for Omega you get:
[tex]\omega=\sqrt{\frac{k}{m}} = \sqrt{\frac{g}{x}}= \sqrt{\frac{9.8}{.0038}}[/tex]
This is where my mistake is, I mistakenly entered .0032 instead of .0038 in my calculator and got the previous result.
BTW it was 485 rpm's
  • · Replies 0 ·
