Maximum Deformation of Springs in a Collision: Deriving the Equations
  • Thread starter Thread starter sumeer@dinsum.c
    Spring
The problem involves a block of mass 20kg dropped onto two springs with different stiffness values, aiming to determine the maximum deformation of each spring during the collision. The context is rooted in mechanics, specifically focusing on energy conservation principles and spring dynamics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the application of energy conservation equations, questioning the assumptions made regarding the equivalent spring constant when springs are arranged in series versus parallel. There is a focus on the relationship between the deformations of the two springs and the need to reason through the assumptions made in the calculations.
Some participants have provided insights into the correct formula for the equivalent spring constant and have urged careful reasoning regarding assumptions. There is an ongoing exploration of how to relate the energies and forces involved in the system, with no explicit consensus reached on the final approach.
Participants note the importance of considering the individual deformations of the springs and the implications of the assumptions made about their arrangement. There is a mention of the need to clarify the relationship between the forces in the springs and the gravitational force acting on the block.
sumeer@dinsum.c
A block of mass 20kg with a spring with a stiffness of 500N/m attached to the bottom is dropped .5m from rest onto another spring of stiffness 800N/m. The weight of the springs can be neglected. What is the maximum deformation of each spring due to the collision.
work = change in kinetic energy + change in potential energy + change in elastic energy
I have assumed that I can add the different spring coefficients, giving me an energy equation of:
work=0= -.5mv^2 + -mg(.5+x) + .5k(x^2)
here k is the sum of the spring coefficents and x is the total deformation of the spring.
I solved the equation, got two answers for x one positive and one negative.
Can I use the ratio of the spring coefficients to work out the individual reformation, and also do i use the positive value calculated for x?
Sorry for the long question, your help is appreciated.
Ermm, if the springs are inline with each other (on top of each other) you add the reciprocals of the constants, so that:
[tex]{k_T}^{-1} = {k_1}^{-1} + {k_2}^{-1}[/tex]
The system adds (becomes stiffer) when the springs are used adjacent to each other.
So I think, from the wording of the question, you need to use this equation maybe:
[tex]k_T = \frac{k_1 k_2}{k_1 + k_2}[/tex] - Your thoughts
But yeah - the kinetic energy term would become [itex]mg\Delta h[/itex] in your equation (because the kinetic energy came about from falling the distance [itex]\Delta h[/itex], cause when it hits the spring, your [itex]mgh = 0[/itex]. Apart from that, logic seems fine...
Let me know how you get on :P
Sam
I do agree with Sam.. Keq = k.k'/(k + k') , is the one to be used.
Since, the two springs are adjacent, force in them must be equal => k.x = k'.x'
Equivalent spring, Keq.X = k.x = k'.x', where X = x + x'.
@ sumeer@dinsum.c
I posted this, just to urge one thing: please REASON OUT your assumptions! Do not make blind assumptions. The assumptions you made (that Keq = k+ k') would have been true, if elongations in both the springs would have been same! x = x', X = x = x', and Ftot = Keq.X = k.x + k'.x'
I hope you get the idea.
Hi Sam,
Thanks for your information, I've managed to work through the problem.
Sumeer
Hi Sameer, I don't how you solved the problem. But see whether it matches with this. Loss of PE of block = mg(0.5 +X). This energy is shared by the two springs and it is equal to 1/2*kx^2 + 1/2*k'x'^2. During the compression force in each spring is kx and k'x'. Hence down ward force =mg + kx and upward force = k'x'. In equilibrium position mg +kx = k'x' and X = x+x', write x' and X in terms of x and substitute it in the above energy equation. Then solve for x, and x'
  • · Replies 20 ·
