Work done on package by gravity: 784JNet work done on package: -37.7J
The discussion revolves around a physics problem involving work done on a package sliding down an inclined chute, focusing on the forces acting on the package, including gravity and friction. The subject area includes concepts of mechanics, specifically work, forces, and friction.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the calculation of work done by gravity and the net work done on the package. Questions arise regarding the correct identification of forces, particularly the normal force and its role in the problem. There is also exploration of the direction of forces and their contributions to work.
The discussion is active, with participants providing insights into the forces involved and their directions. Some guidance has been offered regarding the normal force and its relationship to the work done on the package. Participants are engaging in clarifying concepts and calculations without reaching a definitive conclusion.
Participants are working under the constraints of a homework assignment, which may limit the information available for problem-solving. There is an emphasis on understanding the forces at play and their respective contributions to work, with some assumptions about the setup being questioned.
bigtymer8700
[SOLVED] Work done on box
An 8.00kg package in a mail-sorting room slides 2.00m down a chute that is inclined at 53.0 below the horizontal. The coefficient of kinetic friction between the package and the chute's surface is 0.400.
its asking me for the work done on the package by gravity and then the net work done on the package. wouldn't the work by gravity just be the weight. and for the normal force i just subtracted the frictional force from the normal force. where am i messing up?
W= F cos(53) s
Friction Force= .4(Fnormal)
I already figured out the frictional force to be 37.7 and the force 94J.
bigtymer8700 said:
W= F cos(53) s
I'm afraid this doesn't makes a lot of sense as it stands. Start with the forces:
You have the frictional force correct, but what is F_normal?
What is the weight force on the package? What component of that force points along the incline?
Of these three forces -- normal force, kinetic friction, and weight -- which ones will do work along the incline on the package?
For F_normal I have F_normal = (8kg)(9.8 m/s^2) cos53. is that correct?
and niether of those do work along the incline do they? the kinetic friction is going against it the weight is downwards and the F_normal is up right?
That's right.
The normal force is perpendicular to the direction the package moves, so it does not work on the package.
The kinetic friction force points up the slope and there is a component of the weight force that points down the incline. What are the magnitudes of those forces?
i thought the kinetic friction pointed opposite of the x direction? The component that points down would be the U=mgy correct?
ok i got that part and finished the rest of the problem thanks!
