Calculating energy lost in collisions?
The discussion revolves around calculating energy lost in collisions, specifically focusing on kinetic energy before and after the collision involving two masses with given initial and final velocities.
  • Participants discuss the need for mass and velocity data to perform energy calculations. Questions arise regarding the completeness of the provided information and the necessity of understanding kinetic energy formulas.
Participants are actively clarifying the details of the problem, including the masses and velocities involved. Some guidance has been offered regarding the calculation of kinetic energy, but there remains a focus on ensuring all necessary data is accounted for.
There is an emphasis on the requirement for both masses and their respective velocities to accurately calculate energy changes in the collision. Participants express uncertainty about the completeness of the problem setup.
pebbles
My notes don't provide an equation.
I am given inital and final velocity
Vi=50 m/s
Vf=25 m/s
Thanks.
Vi=50 m/s
Vf=25 m/s
Thanks.
I'm afraid it's worse than that: if you're trying to do an energy calculation, you're going to need a mass as well... If this is a collision problem, you're going to need both masses and the initial and final velocities for each of them.
Are you covering linear momentum in your course right now?
oops forgot to note the masses: each is is 1 kg.
sorry!
Is what you posted originally the initial and final speed of both masses? There still seems to be detail missing from this problem.
In any case, you'll need the formula for kinetic energy. Find the sum of the kinetic energies of the two masses before the collision and compare it to the sum of their kinetic energies afterwards.
agh. no!
what was i thinking?!
ok mass 1= 1.0 kg; initial velocity = 50; final velocity =25
mass 1.0 kg; initial velocity= 0; final velocity = 25
pebbles said:
agh. no!
ok mass 1= 1.0 kg; initial velocity = 50 m/sec ; final velocity =25 m/sec
mass 1.0 kg; initial velocity= 0; final velocity = 25 m/sec
It looks like you now have all the data assembled. How you do calculate the kinetic energy of an object? Find the initial and final kinetic energy for each mass and the total initial and final kinetic energies of the pair.
  • · Replies 17 ·
