Horizontal Speed of bullet fragment
The problem involves a 14-kg shell fired from a gun at a specific angle and velocity, which explodes into two fragments at the peak of its trajectory. The task is to determine the horizontal speed of one of the fragments after the explosion, given that the other fragment falls vertically with an initial speed of zero.
  • Participants discuss the conservation of kinetic energy and momentum in relation to the explosion. Some question whether to assume all kinetic energy transfers to the second fragment or if momentum considerations should be prioritized. Others explore the need to calculate the maximum height and initial vertical velocity using trigonometric relationships.
There is an ongoing exploration of different approaches, including energy conservation and momentum conservation. Participants are sharing insights on calculating vertical and horizontal components of velocity, but no consensus has been reached on the best method to solve the problem.
Participants express confusion regarding the calculations needed to find the height and the initial vertical velocity. There are also discussions about the implications of the explosion on momentum and energy conservation, indicating a need for clarity on these concepts.
bulldog23
[SOLVED] Horizontal Speed of bullet fragment
A 14-kg shell is fired from a gun with a muzzle velocity 125 m/s at 33o above the horizontal. At the top of the trajectory, the shell explodes into two fragments of equal mass. One fragment, whose speed immediately after the explosion is zero, falls vertically. What is the horizontal speed of the other fragment?
I divided the mass by two, because the bullet splits into two equal fragments. I have no idea how to figure out the horizontal speed of the second fragment. Can someone please explain this to me?
A very badly worded question.
Are you supposed to assume all the KE goes into the second half or do you assume that the momentum of the explosion puts all the forward momentum into the second half?
I think you are going to have to do it by energy.
You know the KE at the start. Work out the maximum height reached ( v^2 = u^2 + 2as).
Then you know how much KE has gone into PE.
When the shell explodes all the remaining KE must go into the second half so you know it's total speed.
Think about the path of the second half and you should get it's horizontal velocity.
I'm guessing that you are to assume that all of the KE goes into the second half. Can you help me out, I'm lost?
I am still confused, I don't understand how to figure out the height.
For now just think about the upward velocity.
Draw a triangle with the angle given in the question, the total speed as the hypotonuse and you will get the vertical and horizontal velocities from the other two sides.
You know at the top of the curve it's vertical velocity must be zero.
You know what rate it is slowing down as it goes up ( g = 9.8m/s^2)
And there is a well known equation that says:
V^2 = U^2 = 2 a s where v=final, u=initial velocity, a = acceleration and s=distance.
Be careful, a is -g because it gravity is acting downwards.
So the initial velocity is 125 m/s. The accel is -9.8 m/s^2. I still need the distance right? And then I solve for the final velocity?
The initial velocity is 125m/s at 33deg and the vertical accelaration is -9.8 m/s^2
You have to find the initial vertical velocity to find the height.
can you explain to me how to do that?
so then I just take 125 and divide by -9.8?
The velocity is 125m/s at an angle of 33deg - velocity must always have a speed and direction.
That's equivalent to 125 sin(33) vertically and 125 cos(33) horizontally. You can see this if you draw a triangle.
A nice feature about physics is that you can treat forces at right angles independantly so we can ignore the horizontall bit fro now and just look at the vertical.
It starts off going up at 125sin(33) and slows down at 9.8m/s^2
v^2 = u^2 + 2 a s At the top when u=0 and a = -9.8
125sin(33) ^2 = 2 * 9.8 * s where s (the height) =236.5m
The kinetic energy is = 1/2 m v^2 and potential energy is = m g h
At the top of the curve you have used up some of the initial KE as PE - so we now work out how much KE is left.
KE = 1/2m v^2 - mgh = 1/2* M * 125^2 - M * 9.8 * 236.5 = M ( 1/2*125^2 - 9.8*236.5).
Now the shell is only moving horizontally at the top of the curve so all this kinetic energy is going to go into the horizontal velocity.
But the mass has just halved - so:
M * those numbers = 1/2 1/2 M V^2 where V is the new velocity.
Would this have been solved a bit more easily as a conservation of momentum problem? You just figure out the horizontal velocity, then
[tex]m_1v_1 = m_2v_2[/tex]
fill in the [tex]m_1\ \ v_1 \ \ m_2[/tex] and solve for [tex]v_2[/tex]
I think you HAVE to use conservation of momentum. Since the bullet "explodes" you cannot assume that total energy is conserved.
Doh - I was forgetting that the vertical momentum component was zero when it separates!
What do I put in for m1 and m2?
never mind I got it, thanks
  • · Replies 41 ·
13K
