Can a large number of monkeys write Hamlet?
  • Context: Graduate
  • Thread starter Thread starter phoenixthoth
The discussion revolves around the hypothetical scenario of whether a large number of monkeys could eventually type out the complete text of "Hamlet" given infinite time and a specific keyboard configuration. Participants explore the implications of the "infinite monkey theorem," the probabilities involved, and the conditions under which the monkeys would stop typing.
  • One participant calculates the probability of a monkey typing "Hamlet" character by character, concluding that the expected number of monkeys needed is on the order of (googol)^3465.
  • Another participant notes that the scenario is an example of the "infinite monkey theorem."
  • Some participants question the implications of a "STOP" key, arguing that it introduces ambiguity in the calculations regarding when a monkey would stop typing.
  • Several participants discuss the limitations of the keyboard, particularly the absence of punctuation marks, which they argue would affect the likelihood of producing "Hamlet."
  • One participant suggests that the probability of randomly selecting all the students in a large college is similar to the probability of a monkey typing "Hamlet," emphasizing that while the probability is extremely small, it is not zero.
  • Another participant highlights the vast number of monkeys required and the impracticality of accommodating them in the universe.
  • Some participants express skepticism about the feasibility of the scenario, suggesting that while theoretically possible, it is practically impossible.
Participants generally agree that the probability of a monkey typing "Hamlet" is extremely low, but there is disagreement regarding the implications of the "STOP" key and the calculations surrounding it. The discussion remains unresolved on several points, particularly regarding the definitions and assumptions involved in the scenario.
There are limitations in the assumptions made about the keyboard configuration, the definition of "stop," and the scope of the calculations, which participants acknowledge but do not resolve.
phoenixthoth
I think if they were given enough time, and large means what it sounds like, then the expected value of number of monkeys that reproduce Hamlet, character for character, would be any number you like (so greater than 1 if there were enough monkeys).
Let's say you give them a special keyboard that has only letters, space, and a shift key. Then there are 53 different keystrokes. Only one in 53 is the correct first character in Hamlet.
So 1/53 of the monkeys will get the first character right.
Of those, 1/53 will get the second character right.
There are about 200,000 characters in Hamlet. So the probability a monkey will type out Hamlet is less than (1/53)^200000 which is around 1 times ten to the -344855 power. In other words, there are about 344850 ZEROS before the decimal point. So it's pretty unlikely.
I think a google is 10^100. If you have one google raised to the 3449 power, or so, monkeys, all typing, then the expected value is that ONE of those (google)^3449 monkeys will produce Hamlet. Anything less than (google)^3449 monkeys will PROBABLY not produce Hamlet.
This is to skirt the issue of how many of those monkeys will STOP at HAMLET and not keep going. If a monkey keeps going, that should DISQUALIFY it from being considered a real Hamlet.
So let's revise it and give each monkey the option to stop. So let's model that by having 54 keys instead of 53, where the new 54th key is STOP WRITING.
OK, now the probability that a monkey will type all the right characters in Hamlet and Stop at the right time, without adding extra stuff, is (1/54)^200000 or so which is about 10^(-346479), meaning that now you need (google)^16 times as many monkeys as before to get the expected value of 1 Halmet.
Bottom line: you'll average one copy of Hamlet per every (google)^3465 monkeys you have.
Given the comparison between a million, or even a trillion, to the sort of numbers involved here like needing (google)^3465 to get ONE Hamlet (on average), there is basically no way a million or trillion monkeys will do it, if everything is totally random. It's safe to say that (google)^3465 is incomprehensibly bigger than the number of monkeys that ever lived on Earth or ever will and, so, realistically, no real group of monkeys will ever produce Hamlet.
But since i added the 54th key, I have ignored the fact that all the monkeys who press key number 54 stop and if they stop before Hamlet is finished, there is NO change they will ever get Hamlet. So consider these numbers as upper bounds.
Yes, this is an example of the "infinite monkey theorem".
kewl
Though it is doubtful that the monkeys would write "Hamlet" if the keyboard has no punctuation marks. :P
oh yeah
also.. how do you define "stop" wouldn't you have to wait infinitely long to see whether the monkey ever types again? ;)
how is stop ambiguous? ;)
Terminology: Google is the search engine / advertising / general technology company. The number is googol.
There's a flaw with the "STOP" key addition.
All the other keys can be pressed an indefinite number of times. Your calculations have to factor in that the stop key is NOT pressed UNTIL the other 200,000 characters have been typed.
Under your restrictions (just letters and spaces) I get just under 163,000 characters, which gives about 10^-281057, admittedly pretty large. If capitalizations is ignored it's more like 10^-233312. This is similar to the probability of randomly selecting all the people in a large college out of the world.
As I said: But since i added the 54th key, I have ignored the fact that all the monkeys who press key number 54 stop and if they stop before Hamlet is finished, there is NO change[*] they will ever get Hamlet. So consider these numbers as upper bounds.
So how is STOP ambiguous?[*]Here is another "terminology" error: by change I meant chance. One could call that a typo or spelling error...to each his own.
Terminology: Terminology has to do with definitions. Google vs googol is spelling.
What college has 10^233312 students?
OK, so I get really around 191000 characters but I think you might be missing the point which is that the probability is not zero. However, the way this statement is sometimes made, with numbers in the millions or trillions, the expected number of monkeys producing Hamlet is far less than one.
Yes, I suppose the chances don't change.
Why is that? I think it's obvious that if there is a stop key, the chances change. If there is no stop key, the probability is zero that a monkey will write hamlet while if there is a stop key, there is a chance, albeit small.
I just checked and found the estimated hydrogen atoms in the universe is only 5x10^68.
Obviously we have absolutely no space to accommodate the monkeys.
Maybe in one parallel universe, there are a lot of monkeys banging away at keyboards...
So practically speaking, it's basically impossible.
I was assuming 40,000 to 50,000 students -- a big college, but not unheard-of. There's one 2.5 hours away from me, for example; it seemed reasonable. How do you get 10^233312 students? There are ~6.6 billion people on earth, so
[tex]{6,600,000,000 \choose 50,000}\approx3.9\times10^{277740}[/tex]
It's rather insulting to suggest I don't know the probability is nonzero but small. I did the calculations just as you did, and even gave another example of an event with similar probability. Another example of an event with similar probability would be choosing (uniformly at random) the optimal tour for this TSP circuit.
I don't think anyone has called it practical. If you wanted practical, you should "lock in" correct characters, in which case the work (punctuation and all) could be finished in ~20,000,000 keystrokes.
Point out a hidden assumption
Someone should probably remark that phoenixthoth was trying to compute the probability of outputing the text of Hamlet assuming that each keystroke is made independently of the others. A more useful Markov chain model based on n-grams would product text which would wander but would statistically resemble the letter frequencies, digram frequencies, ... and n-gram frequencies of the text of Hamlet. This was in fact used by Shannon to suggest the meaning (and limitations) of his entropy measure. See http://www.math.uni-hamburg.de/home/gunesch/entropy.html
Note that even obtaining "grammatical text" , much "ageless quality text" by a highly idealized stochastic simulation is implausible. This suggests the limitations of such simulations, not that Shakespeare could not have existed :rolleyes:
I hopefully presume that this discussion has nothing to do with cranky claims about "blind watchmakers".
Shades of SCIgen!
Oh, ok, you mean something like how many different large colleges would be possible, ie, how many ways 50000 students can be selected from the world's population.
The way you phrased it:
(emphasis added by me)
It sounds like you're suggesting there is a college with 10^233312 students.
That sounds like something you should work on.
When you said something implying that 10^233312 students is comparable to a large college, I had my doubts as to whether or not you did know.
  • · Replies 18 ·
  • · Replies 36 ·
12K
  • · Replies 0 ·
