Does Weight Affect Friction in Winter Driving?
The discussion centers around the relationship between vehicle weight and friction during winter driving conditions, specifically on ice and snow. Participants explore how mass affects the frictional force and stopping distance of vehicles under these conditions, considering both theoretical and practical implications.
  • One participant questions the relationship between weight and friction, suggesting that a heavier vehicle may have more friction but also more inertia, complicating stopping ability on ice and snow.
  • Another participant states that the frictional force is proportional to the normal force (weight), implying that increased weight leads to increased friction.
  • A later reply suggests that while heavier vehicles may have greater friction, they also have greater inertia, which could make them harder to stop despite the increased frictional force.
  • One participant introduces the idea that the coefficient of friction may vary in icy conditions, arguing that heavier vehicles could deform the ice or snow more effectively, potentially leading to better deceleration.
  • Another participant expresses uncertainty about the stopping distances of different vehicles, indicating that the interaction between vehicle weight and surface conditions is complex and not straightforward.
Participants do not reach a consensus on the relationship between weight, friction, and stopping distance. There are competing views regarding how these factors interact, particularly in the context of icy and snowy surfaces.
Participants note that traditional definitions of the coefficient of friction may not apply directly to icy or snowy conditions, suggesting that additional factors may influence the friction experienced by vehicles.
6/4 Blues
I want to become a better driver in the ice and snow. Understanding that a vehicle with more mass will resist change in motion more than one with less mass, what would be the relationship between weight and friction? Will a heavier truck have more friction?(assuming these two vehicles had the same tires) Ultimately, would a smaller vehicle with less inertia be easier to stop (in ice and snow) than a much heavier vehicle with more inertia but greater fiction?
The frictional force between two objects is equal to the coefficient of friction times the normal force. So by increasing the normal force (weight of the vehicle) you will increase the frictional force between the tires and the road.
Seems like it would be a trade off. Not sure of the exact numbers though. I would guess that it would be harder to stop the momentum of the heavier vehicle (i.e. take longer to stop it without sliding) even with greater frictional force, due to the fact that you are on ice and the coefficient of friction, and thus frictional force would be significantly smaller in relation to the time required to stop the smaller vehicle's momentum.
Here's some more information on the subject...
http://www.gi.alaska.edu/ScienceForum/ASF8/843.html
You get more friction, and thus more resistive force, but since f = ma
and f = xmg (where x is the coefficient and g is the acceleration due to gravity, hence mg is weight force which is also = to normal force)
thus ma = xmg
and a = xmg/m
a = xg
deacceleration (choosing the deacceleration direction as positive) = x (coefficient of friction) * g (acceleration due to gravity)
So in either case the friction provided gives an equal deacceleration in each case assuming the same coefficient (the same surface).
Tell me if I did something wrong.
Edit: If I wasn't clear this shows deceleration due to friction (on the ground) is not dependent on mass, thus if both vehicles have the same of amount of breaking force the one with the higher inertia will stop last.
Epsilon did it right. The deceleration does't depend on the mass of the vehicle if the friction coeficient is equal.
But I think friction coeficient in this case have some other aspect. Normally when we identify friction coeficient, the surfaces must be smooth and dry and are not deformed. In the case of driving on ice or snow,, the surfaces are different and I may think heavier vehicles decelerate better for they can deform the ice/snow more than smaller ones do.
deleted
Actually you're right, ice would probably be close enough to be equal but snow...
Imagine a small toy car on the snow, it's coefficient would be much smaller then a truck trying to plow through the snow. I'm not sure which would stop first. I think the larger one would still stop later...
  • · Replies 49 ·
  • · Replies 25 ·
