Complex Number Locus: Find Locus of z
The problem involves finding the locus of a complex number \( z \) that satisfies the equation \( \left| \frac{z - 1 - 2i}{z + 1 + 4i} \right| = 1 \). This relates to the geometric interpretation of complex numbers and their distances in the complex plane.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the manipulation of the equation to express it in terms of distances between points in the complex plane. There are questions about applying the definition of magnitude and handling the imaginary parts of the equation.
Some participants have provided insights into interpreting the equation geometrically, suggesting that the locus represents points equidistant from two specific points in the complex plane. There is ongoing exploration of the algebraic manipulation of the equation.
Participants note potential errors in sign during the manipulation of terms and express uncertainty about the correct approach to applying the magnitude definition. The original poster seeks clarification on how to proceed with the imaginary components of the equation.
unique_pavadrin
Find the locus of the point z satisfying:
[tex]\left| {\frac{{z - 1 - 2{\bf{i}}}}{{z + 1 + 4{\bf{i}}}}} \right| = 1[/tex]
2. The attempt at a solution
[tex]\begin{array}{l}<br /> \left| {\frac{{z - 1 - 2{\bf{i}}}}{{z + 1 + 4{\bf{i}}}}} \right| = 1 \\ <br /> \left| {\frac{{\left( {x - 1} \right) + \left( {y - 2} \right){\bf{i}}}}{{\left( {x + 1} \right) + \left( {y + 4} \right){\bf{i}}}} \times \frac{{\left( {x + 1} \right) - \left( {y + 4} \right){\bf{i}}}}{{\left( {x + 1} \right) - \left( {y - 4} \right){\bf{i}}}}} \right| = 1 \\ <br /> \left| {\frac{{x^2 + y^2 - 9 + \left( {2y + 2 - 6x} \right){\bf{i}}}}{{\left( {x + 1} \right)^2 + \left( {y + 4} \right)^2 }}} \right| = 1 \\ <br /> \end{array}[/tex]
im not sure if that is correct but it seemed logical to me at the time, what do i do with the imaginary part of equation?
many thanks,
unique_pavdrin
In line 2 of your attempt at a solution, you switched signs on the y+4 part (to y-4), but it ultimately does nothing to your solution since you didn't follow what you wrote. According to your method, the next step is to apply the definition of magnitude. Have you done this?
no i am unsure on how to apply the magnitude. do i just square it and then square root it, taking the +ve root?
[itex]|f(z)|=\sqrt{f f*}[/itex] where f(z) is a complex function and * denotes complex conjugation.
many thanks,
unique_pavdrin
I wouldn't do all of that calculation. From
you have immediately |z-1-2i|= |z+ 1+ 4i| or |z-(1+2i)|= |z-(-1-4i)|.
We can interpret the left side as the distance from z to 1+ 2i and the right side as the distance from z to -1-4i. In other words, the locus is the set of points equidistant from (1,2) and (-1, -4). That is the perpendicular bisector of the line segment between the points.
  • · Replies 22 ·
  • · Replies 105 ·
13K
