Numerical Method Set of questions
The discussion revolves around numerical methods for finding roots of equations, specifically focusing on the functions f(x) = x³ - 7x + 5 and e^(-x) = x². Participants are exploring how to identify intervals where roots may exist based on sign changes of the functions.
  • Exploratory, Assumption checking
  • Participants discuss the need to find values that cause the function to change signs, which indicates the presence of a root. There is a question about whether trial and error is the best method or if more sophisticated techniques are available.
Some participants have suggested using trial and error to find negative values for the first question, while others have pointed out that the initial interval proposed may not yield a negative root. The conversation indicates a productive exploration of the problem without reaching a consensus.
There is an emphasis on finding integer values for 'a' in the first question and a specific interval for the second question. Participants are considering the implications of their choices on the sign of the function values.
thomas49th
Hi, I'm currently stuck with 2 questions:
1. Given that the negative root of the equation [tex]f(x) = x^{3} - 7(x) + 5[/tex]
lies between a and a + 1 where a is an integer write down a value of a
2. Show that the equation [tex]e^{-x} = x^{2}[/tex] has a root between x = 0.70 and 0.71
Well for both you need to find values that make f(x) differ in sign..
do i use trial and error? Or is there a more sophisticated way?
For the first one you can just use trial an error with negative values...but I can simply see one negative value of x that will make f(x)= ...
f(0) = 5
f(1) = -1
so a = 0
But you see...between 0 and 1 would mean that the root is +ve so you must find f(-1) or f(-2) etc for the root to be -ve
  • · Replies 105 ·
13K
  • · Replies 16 ·
