Prove that the set of transcendental numbers has cardinality c
The discussion revolves around proving that the set of transcendental numbers has the cardinality of the continuum, denoted as c. Participants explore various approaches to establish this relationship without relying on the Continuum Hypothesis.
  • Participants discuss the uncountability of the set of transcendental numbers and consider using the Schroder-Bernstein theorem to find injections between the sets of transcendental numbers and real numbers. Questions arise regarding the existence of a bijection and the implications of the Continuum Hypothesis.
The conversation includes various attempts to construct bijections and clarify assumptions about the cardinality of transcendental numbers. Some participants suggest specific constructions for bijections, while others question the necessity of certain axioms, indicating a productive exploration of the topic.
Participants note that the set of algebraic numbers is countable, which plays a role in their reasoning about the cardinality of transcendental numbers. There is also mention of the axiom of choice in relation to constructing subsets of transcendental numbers.
andytoh
Prove that the set T of transcendental numbers (numbers that do not satisfy some polynomial equation of positive degree with rational coefficients) has the power of the continuum, i.e. has cardinality c.
Here's what I have: Since T is uncountable, then |T|>alephnull . Also, since T is a subset of R , then |T| not> c . Thus, by the Continuum Hypothesis, we must have |T|=c .
But is there a way to get a proof without using the Continuum Hypothesis, by showing directly a bijection between T and R?
Oh, perhaps I can use the Schroder-Bernstein theorem, i.e. find an injection from T to R and an injection from R to T, thus showing that T and R have the same cardinality.
The identity map : T -> R is clearly injective, but an injection from R to T? Inserting the decimal places of pi between all the decimal places of a real number will make the number irrational, but will it be transcendental?
How do you know T is uncountable? Is it because the real numbers are the union of the transcendentals and the algebraics and the latter set is countable? Well, that is how you might start to prove what you want to prove.
Ok, let A be the set of algebraic numbers. Then since A intersect T = empty, then
|A|+|T| = |A U T| = |R| = c
alephnull + |T| = c
|T| = c,
but that again uses the Continuum Hypothesis.
Is there no explicit bijection between the transendentals and the reals? If not, is it because the Continuum Hypothesis cannot be proven?
It is not the continuum hypothesis. It is straightforward to write down a bijection from any infinite cardinal to itself omitting countably many elements. It is no harder than showing that the naturals are in bijection with the even natural numbers.
I also think you misunderstand the concept of proof - the Continuum Hypothesis can be proven to be true from some starting point, just not from the axioms of ZF. That does not mean it 'can't be proven' - with that logic nothing can be proven.
Ok, here's my bijection construction. Let A be the set of algebraic numbers. Let S be any countable subset of the transcendentals T (constructable by the axiom of choice). Then R = A U (T-S) U S. Define f:R -> T by
A -> S (with odd indices) (e.g. a_i -> s_(2i-1) )
T-S -> T-S (identity map)
S -> S (with even indices) (e.g. s_i -> s_(2i)
I think this will be a bijection, proving |T| = |R| = c.
You don't need the axiom of choice to find an countable subset of T. The numbers
n+e, n in N
are a countable subset of T.
Ok S= {pi + n | n is a natural number}
A -> S: a_n -> pi + (2n-1)
T-S -> T-S: r -> r
S -> S: pi + n -> pi + 2n
is a bijection from R to T. Thanks Matt!
  • · Replies 24 ·
