Simple harmonic motion of ornament on tree
The discussion focuses on calculating the period of a hollow sphere ornament acting as a physical pendulum. The mass of the ornament is 2.0×10−2 kg, and its radius is 5.5×10−2 m. The moment of inertia provided is 5MR2/3, which is appropriate for the scenario since the ornament is hung from a tree limb. The distance 'd' used in the period formula is equal to the radius 'R' of the sphere, confirming the calculations align with the given parameters.
  • Understanding of physical pendulums
  • Familiarity with moment of inertia calculations
  • Knowledge of the parallel axis theorem
  • Basic grasp of harmonic motion principles
  • Study the derivation of the period formula for physical pendulums
  • Learn about the parallel axis theorem and its applications
  • Explore the moment of inertia for different shapes, including hollow spheres
  • Investigate the effects of damping on harmonic motion
Students studying physics, particularly those focusing on mechanics and harmonic motion, as well as educators seeking to clarify concepts related to physical pendulums and moment of inertia.
azila
A holiday ornament in the shape of a hollow sphere with mass 2.0×10−2 kg and radius 5.5×10−2 m is hung from a tree limb by a small loop of wire attached to the surface of the sphere. If the ornament is displaced a small distance and released, it swings back and forth as a physical pendulum.
Calculate its period. (You can ignore friction at the pivot. The moment of inertia of the sphere about the pivot at the tree limb is 5MR^2/3.)
Take the free fall acceleration to be 9.80
T = 2pi(square root of (I/mgd))
I = (5MR^2)/(3)
3. The Attempt at a Solution [/b
First of all, I used the moment of inertia they gave me in the problem in the equation. I don't know if that is ok or am i supposed to use the moment of inertia for a hollow sphere equation. Also, the distance, I do not have, so what would I do with that. I was using L/2 and assuming L was the radius but I don't know if that is ok. Could I use the parallel axis theorem? If someone could tell me or guide me in the right path I would appreciate it. Thanks.
First of all: we always solve idealized problem (at least at this level) .. so always look out for possible assumption in the question.
Yes, you can use parallel axis theorem, but what's the need when they have already given you "I".
I have assumed 'R' as the radius of the (thin) hollow sphere.
I think, you didn't understand (or, read carefully) the question. "hung from a tree limb by a small loop of wire attached to the surface of the sphere" -- note that loop is small, so we can assume that hinge point is at the surface itself. It is more than confirmed by the value of 'I' given in question. (Hollow sphere :2MR^2/3. Use parallel axis for an axis touching its surface: 2MR^2/3 + MR^2 = 5MR^2/3.)
Now, you will realize that, d = R (where 'd' is the one to be used in the formula).
I don't think you will need any further assistance.
thanks a lot!
  • · Replies 51 ·
  • · Replies 40 ·
