Does f mean the same thing as f(x) ?
  • Thread starter Thread starter lLovePhysics
    Mean
The discussion revolves around the notation used in functions, specifically whether "f" and "f(x)" are interchangeable. Participants explore the implications of using one notation over the other in the context of describing function behavior, such as increasing intervals and relative minima.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants question the distinction between "f" as a function and "f(x)" as a specific value of that function. There are discussions about when to use each notation in sentences describing function properties, such as increasing behavior and relative minima.
The conversation is active, with various interpretations being explored. Some participants provide guidance on notation usage while others express differing opinions on the appropriateness of each term in specific contexts. There is no clear consensus, but several productive points have been raised regarding the implications of each notation.
Participants note that the definitions and uses of "f" and "f(x)" may vary based on context and that there may be differing expectations from textbooks and teachers regarding notation. There is also mention of the potential for confusion in distinguishing between function notation and specific values.
lLovePhysics
Does "f" mean the same thing as "f(x)"??
I'm wondering if [tex]f[/tex] means the same thing as [tex]f(x)[/tex]. Does [tex]f[/tex] refer more to the graph and f(x) refers to the y-coordinate of the graph?
Which one should I use to complete this sentence?:
___ is increasing on interval (-1,2)
or
___ has a relative minimum at x=0.
My book uses [tex]f[/tex] but my teacher uses [tex]f(x)[/tex] so I'm wondering if my teacher would mark me off if I used [tex]f[/tex]. Probably not right?
Also, the minimums and maximums are y-values right? My teacher says that if the question asks "what is the min/max?" the answer should be given in the y-value. If the question asks "where is the min/max?" the answer should be given in the x-value.
f is a "rule" of assigning values to every member of a set called the domain of f, to a unique member of another set called the co-domain of f. This "f" is a function. (Well, that was not a very precise definition, but it'll do for now.)
f(x) refers to the value that f takes at x. In other words, it is a single point.
I've seen some people (and some books) say something along the lines of "Let f(x) be a function...". But that's not right. It's f that is the function.
An extremum occurs at certain points where f' is zero. As the name suggests, a maximum (or minimum), is the greatest (or lowest) value that the function takes within a specific interval. Therefore it refers to f(x) (or y, if you prefer), where f'(x) = 0. Where this value occurs...that's at x.
Also, questions often ask for the coordinate of the maximum or intersection, etc.
I would always try to write down the answer like
"The maximum/minimum/intersection/... is (y value) at x = (x value)"
then you always give enough information.
"...f which for every x value assigns the value x squared". =] I still don't think that's completely right, but you get my drift :P
It would be correct to say "Let f be a function such that f(x)= x2". There are some mathematicians who advocate the form f( )= ( )2. I'm not quite ready for that!
An extremum occurs at certain points where f' is zero. As the name suggests, a maximum (or minimum), is the greatest (or lowest) value that the function takes within a specific interval. Therefore it refers to f'(x) (or y', if you prefer), where f'(x) = 0. Where this value occurs...that's at x.
Typo: "it refers to f(x) (or y, if you prefer)" NOT f'(x) or y'.
ILovePhysics said:
I'm wondering if [tex]f[/tex] means the same thing as [tex]f[/tex]. Does refer more to the graph and f(x) refers to the y-coordinate of the graph?
Strictly speaking "f" refers to the function itself (which does not necessarily have anything to do with a "graph") while f(x) refers to a specific value of the function. But the notation is "abused" frequently.
or
Strictly speaking, both of those should be f.
My book uses f but my teacher uses f(x) so I'm wondering if my teacher would mark me off if I used . Probably not right?
I wouldn't mark off for either but if you are concerned go with what your teacher uses- the author of your textbook isn't grading you! (Or you could just ask your teacher!)
or
I disagree. The first one should be f and the second should be f(x), else minimum at x=0 would not make much sense (as f may not necessarily operate on x).
:blushing:
Thank you very much, Halls. :)
Gosh, I disagree with you! "f has a minimum at x= 0" makes sense because we had already been told that f is a function of x (i.e. we are using x to represent the independent variable). To say that "f(x) has a minimum at x=0" would not make sense because f(x) is a number (the value of f at some specific x) and it doesn't make sense to say that a number has a minimum!
(Pistols at thirty paces?)
Where?
f(x) is a function in x, it is not a unique number, rather, it depends on x. So f(x) can be argued to mean that it is a number dependent on x, and this number attains a minimum at x=0.
Pistols at wha?
The notion of relative maximum depends on [itex]f[/itex] on [itex](-\epsilon,\epsilon)[/itex], so it would probably be better to use [itex]f[/itex] there.
As with many other notations, it's common to play fast and loose, and rely on context. It's not so much of an issue with [itex]f[/itex] but the trailing parens are sometimes used to indicate that something is a function. This is popular in parametric notation with [itex]x(t)[/itex] and [itex]y(t)[/itex] or when denoting paths [itex]\gamma(t)[/itex].
Aside from context, there's really no good method to distinguish between [itex]x(t)[/itex] referring to a function and the same expression referring to a single value. [itex]f(x)[/itex] is less likely to refer to a function, but you're not likely to confuse anyone by using it that way as long as there is sufficient context. ([itex]\gamma(t)[/itex] by contrast is more likely to be a function.)
f is the set of ordered pairs {(a,b),...}, where each a is in the domain of f and b is the image of a under the mapping f. In particular, if a=x, then b=f(x).
