Second Order Differential Equations
The discussion focuses on solving the second order differential equation y'' - 4y' + 4y = f(x) with f(x) = 25cos(x). The user proposes a particular solution of the form y = Asin(x) + Bcos(x) and derives the first and second derivatives. However, they struggle with substituting these derivatives back into the original equation to find the coefficients A and B. The correct particular solution is y(p) = 3cos(x) - 4sin(x), which can be obtained by setting the coefficients of sin(x) and cos(x) terms to zero and solving the resulting equations.
  • Understanding of second order differential equations
  • Familiarity with trigonometric functions and their derivatives
  • Knowledge of the method of undetermined coefficients
  • Ability to manipulate algebraic expressions
  • Study the method of undetermined coefficients in detail
  • Practice solving second order differential equations with varying right-hand sides
  • Learn how to derive particular solutions for non-homogeneous differential equations
  • Explore the use of linear algebra in solving systems of equations derived from differential equations
Students and professionals in mathematics, engineering, and physics who are working with differential equations, particularly those seeking to understand methods for finding particular solutions in non-homogeneous cases.
Illusionist
Consider the second order differential equation y'' - 4y' + 4y = f(x)
Find a particular solution if f(x) = 25cos(x)
I believe for this type of question I should let y = Asin(x) + B cos(x)
Hence y' = Acos(x) - Bsin(x) and
y'' = -Asin(x) - Bsin(x)
I think everything above is right, and for the rest of the question I should just be able to substitute back into the original formula and find values for A and B.
The problem is when I do substitute back in all I get is a mess and a headache!
Here is what I got by substitution:
-Asin(x) - Bcos(x) - 4[Acos(x) - Bsin(x)] + 4[Asin(x) + Bcos(x)] = 25cos(x)
Hence
-Asin(x) + 4[Asin(x) + Bsin(x)] - Bcos(x) - 4[Acos(x) - Bcos(x)] = 25cos(x)
That's about all I think I can do and I have no idea how to obtain values for A and B. I know the answer is y(p) = 3cos(x) - 4sin(x).
How to get this answer from the above I have no idea, I'm obviously missing something.
Thanks in advance for any advice or help.
You are just about there. Gather your sinx terms then factor the sin, same for the cosx terms, now, since sin x does not appear in the particular solution set its coefficient to zero, solve for A in terms of B. Set the coefficient for the cos x term = 25 and find B.
  • · Replies 27 ·
