Special pattern in the directivity of loudspeaker
  • Thread starter Thread starter hanson
The discussion revolves around the directivity patterns of boxed loudspeakers, specifically how these patterns change from circular to saw-tooth shapes as frequency increases. Participants explore the underlying reasons for this phenomenon, considering aspects of acoustics and wave interference.
  • One participant suggests that the change in directivity pattern is due to interference, questioning the relationship between frequency and interference strength.
  • Another participant explains that the change is related to pressure nodes created at increasing frequencies, referencing the classical problem of the baffled piston in acoustics.
  • A mathematical expression for sound intensity is provided, highlighting the role of a directivity factor in determining the directional nature of sound patterns.
  • It is noted that low-frequency sounds tend to be omni-directional, while higher frequencies require smaller radii to maintain a similar characteristic.
  • A later reply elaborates on the interaction between the source wave from the speaker and the reflected wave from a surface, indicating that increased frequency leads to more nodes in the same space due to shorter wavelengths.
Participants express varying levels of understanding regarding the creation of pressure nodes and the role of interference, indicating that while some explanations are provided, there remains uncertainty and a lack of consensus on the details.
Some participants seek further clarification on the mechanisms behind the creation of pressure nodes, suggesting that assumptions about wave interactions and frequency effects may not be fully resolved.
hanson
hi all.
For boxed loudspeaker, the direcitivity is as shown in the figure below.
The directivity change from a circular shape into a saw-tooth shape when the frequency increases. Why would this be?
I am wondering if this will be caused by interference? But there seem to be no evidence showing that interference will be stronger for higher frequencies?
Please express your views. Thanks
The change in pattern is due to pressure nodes that are created at ever increasing frequencies.
The issue you talk about is a classical problem in acoustics; the baffled piston. The sound intensity can be calculated via
[tex]I_{(r,\theta)} = \frac{\rho_o c k^2 U_{rms} \pi^2 z^2}{4\pi^2r^2}\left[\frac{2J_1(k z sin \theta)}{k z sin\theta}\right]^2[/tex]
Where:
[tex]I[/tex] = sound field intensity
[tex]\rho_o[/tex] = density of the medium
[tex]c[/tex] = speed of sound
[tex]k[/tex] = wavenumber
[tex]U_{rms}[/tex] = RMS speed of the piston surface
[tex]z[/tex] = piston radius
[tex]r[/tex] = radius from piston face
[tex]J_1[/tex] = first order Bessel function
The term in the second set of brackets is a directivity factor. That is the term that is responsible for the directional nature of the the pattern. Kind of interesting note: This is another reason why you see large woofers and small high frequency tweeters. The low frequency sounds are pretty much omni-directional. The higher frequencies require a smaller radius to be somewhat omni directional. It would not be good to have a speaker that has nodal points within your living room.
Where:
Thanks FredGarvin.
But I don't quite understand why pressure nodes will be created when we increase the frequency. Can you explain in a bit more detail?
You are looking at the result of really two waves interacting: the source wave from the speaker and the reflected wave from the, what would be referred to as, the ground or reflecting plane. As the frequency of the source increases, the wavelength goes down which means there will be more nodes within the same space to interact with each other. So, to get to point, it is due to interference between the two waves that causes the pattern.
Thanks FredGarvin again for the clear explanation.
You are so helpful.
  • · Replies 29 ·
15K
