Regarding the density of an Object in another density layer
  • Context: Graduate
  • Thread starter Thread starter Manjunathan
    Density
The discussion focuses on the dynamics of an object with a density equal to Layer 1 being introduced into Layer 3, which has a lower density. The user seeks to calculate the speed at which the object will ascend to Layer 1 after being introduced into Layer 3. Key factors include gravitational force (mg), buoyancy, viscosity, and the coefficient of drag, which are essential for determining the object's movement through the different density layers.
  • Understanding of buoyancy principles in fluid dynamics
  • Knowledge of gravitational force calculations (mg)
  • Familiarity with viscosity and its effects on fluid motion
  • Concept of drag coefficient in dynamics
  • Research fluid dynamics principles related to buoyancy and density
  • Learn about calculating gravitational force and its impact on objects in fluids
  • Study the effects of viscosity on the motion of objects in different density layers
  • Explore the concept of drag coefficient and its role in fluid resistance
Students and professionals in physics, particularly those studying fluid dynamics, as well as engineers and researchers involved in material science and buoyancy-related applications.
Manjunathan
Hi All,
Iam doing a post graduate science student from india, , I have a query regarding the density of a object (liquid).
My query is,
Let say if I have three layers from ground level each has different density as mentioned below,
(Layer 1 (high density hence below), Layer 2(2nd highest) and Layer 3 (lowest) . consider Layer 1 has 10 meter of height, layer 2 has 10 meters of height
suddenly i introduce a object of layer 1 density in layer 3, As per the theory the introduce layer one object should go up to layer 1.
Iam not able to calculate the how much faster the introduced object will reach layer 1?
Is there any formulae to calculate this ?
Thanks in Advance.
Looking forward for your reply.
--Mnathan
In addition to determining the forces mg and buoyancy, one needs the viscosity and/or coefficient of drag since this is a dynamics problem.
  • · Replies 22 ·
  • · Replies 25 ·
