Alternative Energy Windmill Ideas
The discussion revolves around the design and construction of a small-scale windmill intended to lift a weight of 200 grams twelve inches above the base plane within a specified time frame. Participants explore various design considerations, materials, and mechanisms to optimize the windmill's performance.
  • The original poster suggests using an abundance of blades with a decent pitch and is uncertain about the material for the blades.
  • There is a proposal to use a small vehicle that will be pulled up a ramp by the windmill's mechanism.
  • The original poster questions whether having more or fewer blades is beneficial and emphasizes the importance of minimizing air unaffected by the blades.
  • One participant suggests considering the use of pulleys as part of the design.
  • Another participant provides a formula for calculating power generated by the windmill, highlighting the importance of aerodynamic blade design and balance, while stating that the number of blades may not be a critical factor.
  • A later reply critiques the timing of responses, suggesting that older questions may not receive attention and encouraging focus on more current inquiries.
Participants express differing views on the optimal design features of the windmill, particularly regarding the number of blades and the use of pulleys. The discussion remains unresolved with multiple competing ideas presented.
There are limitations regarding the assumptions made about materials, design specifics, and the effectiveness of proposed mechanisms. The discussion does not resolve these uncertainties.
This discussion may be useful for individuals interested in DIY renewable energy projects, particularly those exploring wind energy applications and mechanical design principles.
jstew2189
Here's the problem...
I am to build a simple windmill (small scale) to lift an x amount of weight twelve inches above the base plane. The required amount is to lift 200 grams, 12 inches in 2 minutes or less. The materials are to be mostly recycled; however, I am alotted $15 to buy any new materials needed. The windmill will be sat in front of a standard box fan to turn the mill.
The basis for my idea is this:
1. An abundance of blades, with a decent amount of pitch. Material not yet known
2. To lift the weight, I will pull a small vehicle up a ramp that will eventually become 12 inches high.
3. The windmill part will turn a drive shaft. This drive shaft will be connected via belt to another drive shaft. This shaft will have a string that will wrap around it to pull the car up the ramp.
What I wanted to know is...
what is the basis to have a successful windmill? Is more blades or less blades good? Minimizing air unaffected going through is key right?
Could anyone give me some alternative ideas that would succeed?
Have you put any thought into the use pulleys?
Dear friend,
We can get the Power generated from a wind mill using the formula p=1/2dAV^3
where d is air density in Kg/m^3, A is the swept Area again depends on Blade Dia, and v
is the wind speed in m/sec. The blade has to be aerodynamically designed and
balanced and I think nothing related to no. of blades.
Your input is great, rsrajeesh, but jstew posted his question nearly 4 months ago, to put things into perspective. Try helping out people who have more current questions - people who don't get their questions answered within 2 weeks generally won't ever look back on them.
  • · Replies 24 ·
9K
  • · Replies 43 ·
  • · Replies 67 ·
  • · Replies 18 ·
15K
  • · Replies 33 ·
31K
