Where the total electric field is equal to zero?
The discussion focuses on determining the point along the x-axis where the total electric field is zero due to two point charges: -2.5 µC and 6.0 µC, which are 1.0 m apart. The user correctly applies the equations for electric field (E=F/q) and force (F=K(Q*q)/d²) to derive the net electric field equation. The solution reveals that the electric field is zero at a point 1.82 m to the left of the 6.0 µC charge, while the other potential solution was disregarded as it lies between the two charges where fields cannot cancel.
  • Understanding of electric field concepts and equations
  • Familiarity with Coulomb's Law (F=K(Q*q)/d²)
  • Knowledge of quadratic equations and their solutions
  • Basic principles of superposition in electric fields
  • Study the concept of electric field superposition in detail
  • Learn how to solve quadratic equations effectively
  • Explore the implications of electric field direction and magnitude
  • Investigate the behavior of electric fields in multi-charge systems
Students studying electromagnetism, physics educators, and anyone seeking to understand electric field interactions between point charges.
barrett
Two point charges of -2.5 µC and 6.0 µC lying along the x-axis are 1.0 m apart. Locate the point (other than infinity) at which the total electric field is zero.
I was thinking: E=F/q
and
F=K (Q x q)/d^2
But I'm not quite sure how to use them.
Using the second equation I found F to be -.135. But I don't think that's right, and then when plugging that into the E=F/q. E would have to be zero, since I'm trying to find where the total electric field is zero? Then there's no solutions other than infinity, are there? And what exactly is q in the first equation. I really have no idea what's going on here.
If the electric field is zero, is it the case that the force is also zero? So find the point(s) where the net electric force or field is zero.
I found an example online and I think I substituted the right numbers in for this problem, is this how it would be solved? (I didn't understand the equation below and where it came from: KQ/x²-2.4KQ/(x+1.00)²)
Enet=Esub1 + Esub2 = KQ/x²-2.4KQ/(x+1.00)²
The Ks and Qs cancel out leaving:
1/x² = 2.4/(x+1.00)²
And then get it into a quadratic:
1.4x² - 2x -1=0
And find it to be 1.82 m to the left of charge Q. I ignored the other root, -.39m because that would be between the two charges where the fields cannot cancel out.
Am I on the right track?
  • · Replies 16 ·
