Thread Closed
Impulse and Momentum
Share Thread Thread Tools
Nov1-07, 07:15 PM   #1
An object of mass 3.0 kg is projected into the air at a 45° angle. It hits the ground 3.7 s later. What is its change in momentum while it is in the air? Ignore air resistance.
_____ kg·m/s downward
2. Relevant equations
F[tex]\Delta[/tex]T = [tex]\Delta[/tex]P = m[tex]\vec{v}[/tex][tex]_{f}[/tex]-m[tex]\vec{v}[/tex][tex]_{i}[/tex]
3. The attempt at a solution
This is a really basic question i am sure but i am getting thrown off by the 45 degree angle what do I do?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Nov1-07, 08:30 PM   #2
The object moves in projectile motion, so you need to use the equations for constant acceleration, and the two projectile equations relating each component of the initial velocity to the initial velocity vector. This will allow you to find the initial and final velocities of the mass. Does this make sense?
Nov4-07, 04:24 PM   #3
No this doesnt make any sense to me at all. I know this should be a very simple problem but i dont know wat to do
Nov4-07, 04:35 PM   #4
Is this question worded exactly as you say? I don't know if we have enough info to solve the problem.
Nov4-07, 04:40 PM   #5
it is worded exactly how it was posted. i copied and pasted it
Nov4-07, 04:48 PM   #6
Mentor
You have all the information needed to figure out the initial and final velocity of the mass. (It's just a change in momentum question, not really an impulse question.)
Nov4-07, 05:18 PM   #7
I still do not understand how to figure it out. I knwo it is a change in momentum question but i dont know how to do it.
Nov4-07, 06:32 PM   #8
can anybody help on this one?
Nov4-07, 06:35 PM   #9
Start by considering the object's movement in the vertical direction. It moves with constant acceleration, so we can use a kinematic equation. We'd have:
[tex] y = y_0 + v_{0y}t - .5gt^2 [/tex]
And we know that [tex] v_{0y} = v_0sin\theta [/tex]
Now you can solve for the initial velocity, right?
Nov4-07, 06:42 PM   #10
Recognitions:
Homework Helper Homework Help
At the point of projection the vertical component of the velocity is vsin(theta). By using angle of projection and time of flight you can find this velocity. Just before the object hits the ground this velocity is the same but the direction is changed. So take one as positive and other as negative and find the change in velocity and hence momentum.
Nov4-07, 06:44 PM   #11
if i took one as postive and one as negative wouldnt they just cancel each other out if they were the same? or is it a negative minus a negative?
Nov4-07, 06:51 PM   #12
Recognitions:
Yes. It is a negative minus a negative = positive.
Nov4-07, 06:55 PM   #13
negative minus a negative = a bigger negative
Nov4-07, 07:01 PM   #14
You can work it out on paper and see if it's true on not.
Nov4-07, 07:03 PM   #15
I have been trying to do that. I just dont know how to do it thats why im having problems with this problem. It is an extremely easy problem, for some reason I cannot figure out how to incorporate the angle into the F(deltaT) = mvf-mvi equation.
Nov4-07, 07:06 PM   #16
You have the mass, all you need are the initial and final velocities. Lets start by using the equation:
where [tex] v_{0y} = v_0sin\theta [/tex].
You assume that y is zero, because the object moves up some distance, and comes back down covering that same distance, right?
Nov4-07, 07:17 PM   #17
Recognitions:
F(deltaT) = mvf-(-mvi ) = ?
Thread Closed
Thread Tools
Similar Threads for: Impulse and Momentum
Thread Forum Replies
Impulse momentum Introductory Physics Homework 1
Momentum, Impulse and consevation of momentum? Calculus & Beyond Homework 1
Impulse and momentum Introductory Physics Homework 1
Impulse/Momentum Introductory Physics Homework 1
Momentum and Impulse! Introductory Physics Homework 9
