Absorption by Plants: Can a Plant Take in Water?
  • Thread starter Thread starter ritwik06
    Absorption Plants
The discussion centers on the absorption of water by a small plant stripped of its leaves and placed in a beaker of water, covered with oil to prevent evaporation. It is established that the plant will not absorb water effectively due to the absence of leaves, which play a crucial role in transpiration and water uptake. The inquiry emphasizes understanding the mechanism of water movement through plants, particularly the role of roots and stems in this process.
  • Understanding of plant physiology, specifically transpiration.
  • Knowledge of the structure and function of plant roots and stems.
  • Familiarity with the concept of osmosis in biological systems.
  • Basic principles of experimental design in biology.
  • Research the process of transpiration in plants and its significance.
  • Study the role of roots in water absorption and nutrient uptake.
  • Learn about osmosis and its effects on plant cells.
  • Explore experimental setups for studying plant water absorption.
This discussion is beneficial for biology students, plant physiologists, and educators looking to deepen their understanding of plant water absorption mechanisms and experimental biology.
ritwik06
A small plant is stripped off its leaves and is placed in a beaker containing water. The water surface is covered with oil to prevent evaporation of water. Will the plant absorb water within a couple of hours or so?
This is homework. Please post in the correct forum.
If this is homework, please ask a moderator to move to the homework section.. If you happen to be doing some light reading on plant physiology and this question came to you, it can stay here.
Before offering my thoughts on this, I wonder what do you think will happen to this plant under those conditions and why? (if you are not sure, here's a hint.. Look up the mechanism of how water moves through a plant).
Something you ought to clarify: When the plant is placed in the beaker of water, besids missing its leaves, is it otherwise intact (roots & stems)?
