Oscillation Motion Frequency: Spring & Block
The discussion centers on calculating the frequency of oscillation for a spring-block system. The block stretches the spring by 2.0 cm, establishing a new equilibrium. The relationship between the spring constant (k) and the mass (m) is defined by the equation mg = k * 0.02 m, where g equals 9.81 m/s². The angular frequency (ω) is related to k and m through the formula ω = √(k/m), which is essential for determining the oscillation frequency.
  • Understanding of Hooke's Law and spring constants
  • Basic knowledge of oscillatory motion and frequency
  • Familiarity with gravitational force calculations
  • Concept of angular frequency in harmonic motion
  • Study the derivation of the formula for angular frequency in spring systems
  • Learn about the effects of mass on the frequency of oscillation
  • Explore real-world applications of oscillation frequency in engineering
  • Investigate the relationship between damping and oscillation frequency
Physics students, mechanical engineers, and anyone interested in the principles of harmonic motion and spring dynamics.
SCI2007
A spring is hung from the ceiling. When a block is attached to its end, it stretches 2.0 cm before reaching its new equilibrium length. The block is then pulled down slightly and released.
What is the frequency of oscillation?
I'm totally Stuck help would be appreciated...
Knowing that the weight of the block is mg, where m is the mass and g = 9.81 m/s2 must = the spring force = k * 0.02 m,
thus m 9.81 m/s2 = k 0.02 m
Then what is the relationship between angular frequency and k and m?
http://hyperphysics.phy-astr.gsu.edu/hbase/shm2.html#c2
  • · Replies 27 ·
11K
