Double integration with cos x^2
  • Thread starter Thread starter raynoodles
    Cos Integration
The problem involves double integration of the function ycos(x^2) with specified limits for x and y. The original poster expresses confusion regarding the integration of cos(x^2) and the implications of including y^2 in the integration process.
  • Exploratory, Assumption checking
  • Participants question the correctness of the limits of integration and whether they should be adjusted. There is also discussion about the nature of integrating cos(x^2) and its relation to elementary functions.
Some participants have provided guidance on reparametrizing the region of integration, suggesting that this may lead to a clearer path forward. However, there is no explicit consensus on the approach to take, and multiple interpretations of the problem are being explored.
There is uncertainty regarding the limits of integration and the handling of the function cos(x^2), as well as the potential addition of y^2 in the integration process. Participants are encouraged to clarify these aspects further.
raynoodles
ok so I have the problem ycos(x^2)dxdy with parameters dx=y^2 to 1 and dx=0 to 1
the first problem I have is integrating cos with respect to x^2. is it a double angle identity? the second is how do I go further if Y^2 gets added into the mix later?
The attempts I have made have made me even more confused than before. I looked up how I could integrate cos x^2 and could not find a clear answer.
Help is appreciated.
Did you copy the limits of integration correctly?
Should it be x going from y^2 to 1 and then y going from 0 to 1?
What is the identity of cosx^2? if you don't know then look it up in your book.
It can't be expressed in terms of elementary functions, look up the Cosine Fresnel integral for the solution.
Not so fast.
Try reparametrizing your region of integration. If you first integrate wrt y, then wrt x you may find a solution. (Hint: You will).
O sorry I should have read the whole question, Mainly just read post 3 and replied to that.
  • · Replies 19 ·
