Proving f(x) = x^4 + 4x + c has No More than 2 Roots
  • Thread starter Thread starter grapeape
    Roots
The problem involves proving that the function f(x) = x^4 + 4x + c has no more than two roots. Participants are exploring the implications of the function's derivative and critical points in relation to the number of roots.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of Rolle's Theorem and the Mean Value Theorem (MVT) to analyze the roots of the function. There is consideration of the function's derivative and critical points, with questions about how to eliminate the possibility of additional roots.
The discussion is active, with participants sharing insights about the critical point and the behavior of the function. Some participants express confusion about the relationship between the critical point and the number of roots, while others suggest graphical methods to support their reasoning. There is no explicit consensus yet, but productive lines of inquiry are being explored.
Participants are working under the constraints of a homework assignment, which may limit the methods they can use. There is an ongoing examination of the implications of having only one critical point and how that relates to the number of roots of the function.
grapeape
Show that f(x) = x^4 + 4x + c = 0 has at most 2 roots.
I'm not really sure how to approach this problem, I think I have to use the IMVT / Rolle's Theorem / MVT.
Any help to even get me started would be greatly appreciated!
Rolle's theorem sounds good! What is the derivative of x4+ 4x+ c? Suppose there were in fact three differerent roots. Apply Rolle's theorem on the two different intervals.
It's derivative has only one root, and so the f(x) has only one critical point
the derivative is 4x^3 + 4, which has a zero at -1. But how do I eliminate the possibility of other zeroes? do I have to take the double deriv? and also how do I prove the f(x) has only 2 zeroes?
-1 is the only critical point of f(x). Draw a picture to convince yourself that f(x) has at most two roots.
So, since there is only 1 critical point, how do we know that there aren't more? asides from using a graphing calculator. By looking at the first derivative and finding 1 root, does that automatically mean that there are two roots? I'm a little confused on how Rolle's theorem ties into this. Am I supposed to look at the second derivative? So far, I've written that since there is only one critical point, it means that the graph of f(x) only changes from decr. to incr. once, so there can only be two zeros? is that right?
There's only one real solution to x^3 = -1, the other two solutions are complex.
alright, thanks. I am pretty sure I got it now. I used IMVT to prove that between -2, and -1 there is another 0, and since there is only 1 critical number it is the only other 0 asides from (0,0). Seems right, thanks for the help Andy and Halls!
  • · Replies 62 ·
10K
  • · Replies 16 ·
  • · Replies 105 ·
13K
