Changing or moving magnetic field
The discussion centers around the nature of electromotive force (emf) in relation to changing or moving magnetic fields. Participants explore the conditions under which emf is generated, referencing Faraday's Law and the implications of moving magnetic fields in various contexts, including theoretical and experimental scenarios.
  • Some participants propose that induced emf is produced by changing magnetic flux, regardless of whether the magnetic field is moving or changing.
  • Others question the validity of emf generation if the magnetic field is moving but the flux density remains unchanged.
  • One participant emphasizes the importance of understanding Faraday's Law in this context.
  • Another participant discusses historical perspectives, referencing Einstein's work on the magnet/conductor problem and the implications for the Lorentz force equation.
  • Several participants argue against the notion that magnetic field lines can be said to "move," suggesting that this leads to incorrect calculations and misunderstandings of electromagnetic principles.
  • One participant shares articles that critique the concept of moving magnetic field lines and discusses the behavior of a rotating magnet and its effects on electric fields.
  • Participants speculate on the behavior of magnetic fields in superconducting rings and question whether the magnetic field would rotate with the ring.
There is no consensus among participants regarding the nature of emf generation in relation to moving or changing magnetic fields. Multiple competing views remain, particularly concerning the interpretation of magnetic field movement and its implications for electromagnetic theory.
Participants express uncertainty about the implications of moving magnetic fields, the definitions of magnetic flux, and the conditions under which emf is generated. There are references to specific scenarios and theoretical frameworks that may not be universally accepted or understood.
This discussion may be of interest to those studying electromagnetism, physics students exploring the principles of electromagnetic induction, and researchers examining the theoretical implications of magnetic fields in various contexts.
granpa
is an emf produced by a changing magnetic field or by a moving magnetic field?
The induced emf will be produced if the magnetic flux is changing through the element. Whether it field is moving wrt to the element or the field is changing, it does not matter. Just the flux density has to change.
what if the magnetic field is moving but the flux density does not change?
http://en.wikipedia.org/wiki/Moving_magnet_and_conductor_problem
Einstein's 1905 paper that introduced the world to relativity opens with a description of the magnet/conductor problem.[1]
“ It is known that Maxwell's electrodynamics--as usually understood at the present time--when applied to moving bodies, leads to asymmetries which do not appear to be inherent in the phenomena. Take, for example, the reciprocal electrodynamic action of a magnet and a conductor. The observable phenomenon here depends only on the relative motion of the conductor and the magnet, whereas the customary view draws a sharp distinction between the two cases in which either the one or the other of these bodies is in motion. For if the magnet is in motion and the conductor at rest, there arises in the neighbourhood of the magnet an electric field with a certain definite energy, producing a current at the places where parts of the conductor are situated. But if the magnet is stationary and the conductor in motion, no electric field arises in the neighbourhood of the magnet. In the conductor, however, we find an electromotive force, to which in itself there is no corresponding energy, but which gives rise--assuming equality of relative motion in the two cases discussed--to electric currents of the same path and intensity as those produced by the electric forces in the former case.
At the time of Einstein in 1905, the field equations as represented by Maxwell's equations were properly consistent. The Lorentz force equation, however, had to be modified in order to provide unique particle trajectories upon which all observers could agree.
It is an error to think that field lines move. It can lead to calulations which are wrong. For example: Consider a rotating magnet like the one in this page
http://www.geocities.com/physics_world/em/rotating_magnet.htm
If one were to claim that the field lines are rotating with the magnet then calculated the force per unit charge and called that an "electric field" then when you take the curl you will not get zero as is reqwuired by Maxwell's equations. I have two articles on the idea of moving field lines and how it is meaningless to speak of them. Say the word and I'll make them available.
Best wishes
Pete
rotating magnet
Best wishes
Pete
http://www.geocities.com/physics_world/em/image_gif/em11-im-01.gif
considering how magnetic fields are produced i am not sure i would expect the field of a rotating magnet like that in the picture to be moving anyway.
Wait a minute... The Lorentz force equation is Lorentz invariant too.
Best wishes
Pete
Please will you upload them.
cheers
cheers
Sure. It'd be my pleasure to. :smile: Here are the two of them -
http://www.geocities.com/pmb_phy/Webster_1963.pdf
http://www.geocities.com/pmb_phy/ajp_apr1961_webst.pdf
This one I just found now and is straight to the point.
http://plasma.colorado.edu/phys7810/articles/Falthammar_MovingFieldLines_2007.pdf
As such it appears like a good article. The author states
Another example of how the concept of
moving magnetic field lines can be deceptive
is that of a homogeneously magnetized conducting
sphere surrounded by vacuum and
rotating around its axis. For someone thinking
of magnetic field lines as entities that
can ‘move,’ it is a not an uncommon fallacy
to believe that the magnetic field lines outside
the spherical magnet ‘rotate with the magnet’
and that this rotating field is capable of exerting
a force on a test charge at rest, due to the
percieved ‘relative’ motion between the test
charge and the magnetic field.
What really happens is very different. As
the spherical magnet is conducting, a charge
on its surface will be subject to a magnetic
force. This causes a redistribution of charges
until the electric field from these charges
gives a force that precisely balances the
magnetic force. The result is an electrostatic
potential on the surface of the sphere with
the equator having a potential opposite to
that of the poles.
I have no others so if someone knows of any which are related to this topic please let me know. I'm seeking such articles right now. There is mention of this in the problem section of Chapter11 in Classical Electromagnetic Theory, by Jack Vanderlinde, John Wiley & Sons, Inc., (1993). See page 316 problem 11-8
11-8 Find the electric field appearing around a uniformly magnetized sphere rotating at an angular frequency [itex]\omega[/itex] << r/a about the central axis parallal to the magnetization.
Please let me know if I can help with anything else. :smile:
Best regards
Pete
imagine a superconducting ring with a current flowing around it and therefore a magnetic field surrounding it. if i spin the ring around an axis passing through its center then i see no reason to think that the magnetic field will rotate.
furthermore if the magnecic field extends to infinity then wouldn't the velocity of the field increase without limit as one went further from the magnet?
And in this case there would be no magnetic field generated either.
Pete
You need to be a bit carefull when talking about superconducting rings in this case. Quite a few people have probably seen demonstrations where a YBCO "tablet" is levitating above a permanent magnet (cooled by LN2).
The "problem" with YBCO is that it is a type II supeconductor meaning it will be penetrated by flux lines when cooled in a magnetic field. This is the reason why the YBCO is "stuck" on top of the magnet (if you try the same experiment with a zero-field cooled piece of YBCO there is no stable position).
Anyway, my point is that the the field in this configuration is NOT symmetric and you can actually rotate the magnet my rotating the piece YBCO even if the latter is perfectly round; but this is ONLY due to the fact that the flux lines are pinned in the YBCO.
I.e. what granpa writes is correct in MOST cases, but not always.
I used to do this demonstration when I was teaching a few years ago and while it is a neat experiment it can be quite confusing for the students since YBCO does not behave like the superconductors they read about in their textbooks.
Pete
i can only assume that you didnt understand what i said. the ring has a current therefore has a magnetic field. spinning would have no effect on that field at all.
superconductivity has nothing to do with my point. forget superconductivity. imagine that its a normal ring of metal with a battery producing a current in it. spinning the ring will not effect the magnetic field. there is no reason to think that the magnetic field would rotate.
Actually I meant to say
That should have read
And in this case there would be no electric field generated either.
Consider the example I gave here
Read from Eq. (14) on to see what the volume charge density and surface charge density are non-zero and yet the total charge is zero. This configuration of charge will produce an electric field. This can't happen with a ring of current.
Pete
Pete
perhaps i am missing something but that website seems to have nothing to do with moving magnetic fields. its about the effects of relativity on moving charges in a conductor. further it assumes that there are moving charges in a permanent magnet, which seems very doubtful to me.
The magnet has a magentic field. It used to be thought that the rotating magnet carried its field with it, i.e. that the magnetic field rotated with the magnet. In fact that's part of the subject matter in one of the articles I posted the URL to.
... its about the effects of relativity on moving charges in a conductor. further it assumes that there are moving charges in a permanent magnet, which seems very doubtful to me.
Why does it seem doubtful to you?
Besides, that is only a model of a magnet that I'm employing in order to describe the mechanism of the charge distribution. If the current loops bother you that much then ignore them. Focus on the equations for the polarization instead.
Pete
Yes, I understood that. But my point is that you need to be carefull about usings superconductors as an EXAMPLE when you talk about magnetic fields since quite a few people have seen the YBCO demonstration and that does not quite agree with the explanation you gave.
It is probably less confusing to talk about e.g. a perfect conductor instead of a superconductor.
because permanent magnetization is the result of spin orientation of the electrons. no current is involved.
Perhaps the best proof that magnetic field lines do not rotate with the rotating magnet can be found in the device known as "homopolar generator" or "Faraday disk" http://en.wikipedia.org/wiki/Homopolar_generator
In this experiment a rotating magnet fails to induce currents in a metal disk next to it.
Eugene.
http://en.wikipedia.org/wiki/Faraday_paradox
but this only indicates that the magnetic field of a rotating magnet does not move (considering how the field is produced, i wouldn't expect it to move anyway). it does not prove that all magnetic fields don't move.
First off that was a page under classical physics so no quantum properties were used to explain the mechanical properties. There are two components of the magnetic moment of an atom. One is the magnetic moment of the orbiting electron, which provides a small current, while the other is the spin magnetic moment. While very small, almost neglegible, its still there. Often in EM we use current loops to create models for calculations and the one of modeling a bar magnet, while never used in real life, can make a classical explanation of something very useful as in my case.
Pete
Pete
1 the electrons don't actually orbit the nucleus.
2 if the magnetic field can be produced by any method any method that doesn't require a currrent then that casts doubt on the conclusions of that website.
3 even if the magnetic field is produced by a current i never did see any reason to expect that the field would rotate with the magnet.
4 the website is only about rotating magnetic fields, not moving magnecic fields in general.
rotating the magnet does not produce any current in the apparatus BUT moving the magnet will produce a current. if one still insists that the field doesn't move then the only explanation for the emf that i can imagine is that the emf is produced because the strength of the field is changing.
constant magnetic fields are easy to produce. it should be rather easy to construct an experiment in which a constant magnetic field is moved over a conductor and see whether any emf is produced.
Take a bar magnet and rapidly insert it into a solenoid. There will be a current through the solenoid. Does it answer your question, or I misunderstood it?
Eugene.
Eugene.
the field around the bar magnet is irregular therefore the stregth of the magnetic field at anyone point on the solenoid would be changing as the bar magnet moved.
the strength of the field must be constant, like that inside a very long solenoid.
So, suppose I put a wire loop inside a long solenoid and then start to move the solenoid along its axis (or perpendicular to its axis?). You are asking whether there will be current in the loop? Do I understand you correctly?
Eugene.
Eugene.
yeah.
the solenoid would have to be moved perpendicular to its field lines (perpendicular to its axis).
This is getting way off track and now has nothing to do with the original thread. Since you're refusing to acknowledge that it was but a mere model, a very common model at that, I will no longer respond to this line of discussion. Especially since after all these posts you are unable to figure out that a rotating magnet has mistakenly been interpreted as a magnetic field rotating with the magnet and that you don't graps that this means that the field is moving according to this view. Sorry but this is very tiring and of no use to me or the OP.
granpa: Please don't take those as personal criticisms. I am criticizing what I read and not who wrote it.
Pete
Thanks mate.
that of the poles.
Best regards
Pete
  • · Replies 42 ·
  • · Replies 22 ·
  • · Replies 17 ·
