"webassign" problem, CENTRIPETAL ACCEL
  • Thread starter Thread starter lettertwelve
    Centripetal
The problem involves calculating the magnitude of centripetal acceleration for a customer in a revolving restaurant, specifically at a distance of 14.5 m from the center, with a complete turn occurring every hour. The context is centered around the application of centripetal acceleration formulas.
  • Mixed
  • Participants discuss different equations for centripetal acceleration, with one participant attempting to use a formula provided by their teacher. Others suggest alternative approaches, including the use of tangential velocity.
There is an ongoing exploration of the correct formulas to use for the problem. Some participants have shared their calculations and results, noting discrepancies and questioning the validity of the initial equation provided by the teacher. Guidance has been offered regarding the use of tangential velocity in relation to centripetal acceleration.
One participant notes a potential error in the formula they were given, specifically regarding the squaring of the pi term. There is also mention of a possible glitch in the webassign system affecting the results.
lettertwelve
[SOLVED] "webassign" problem, CENTRIPETAL ACCEL
The Emerald Suite, a revolving restaurant at the top of the Space Needle in Seattle, Washington, makes a complete turn once every hour. What is the magnitude of the centripetal acceleration of the customer sitting 14.5 m from the restaurant's center?
4*pi*R(radius) / T^2
where T=time
so then it would be
4*pi*14.5/3600^2, which gives me: 1.41E-5
but it's showing me that its incorrect...but i don't see how!
EDIT: also, is there a difference between the magnitude of centripetal acceleration as opposed to mere centripetal acceleration?
The tangential velocity "v" is [tex]v = \frac{2 \pi r}{T}[/tex] if I remember correctly. Can you tell me what equation you used for the centripetal acceleration?
i used 4*pi*R/T^2, as my teacher directed in class for this particular problem.
for T i converted it to seconds
The equation you posted will give you the units for acceleration, but I've never seen that equation before. Try using the equation for tangential velocity that I gave you, and plug it into [tex]a_{centrip} = \frac{v^2}{r}[/tex].
I tried your equation, and got 4.41E-5, which gave me the correct answer. i don't understand why my teacher gave me that equation though...
i actually used your equation yesterday, and got the same answer. it must have been a webassign glitch?
thank you anyways.
my mistake was that i didnt do the tangential velocity first.
You're welcome. It'd be interesting to know where your teacher got that equation, but I'm glad it all worked out :)
There is an error here, the pi term should be squared. That's why you didn't get the correct answer with it.
That equation is just the result of substituting [tex]v = \frac{2 \pi R}{T}[/tex] into [tex]a=\frac{v^2}{r}[/tex]
13K
  • · Replies 26 ·
16K
