Drag Vs Depth Calculator: Object Velocity, Mass and Weight
The discussion revolves around calculating the depth of an object being towed through water, considering various factors such as velocity, mass, weight, and the characteristics of the towing line. Participants explore the relationship between these variables and how they affect the drag and depth of the object in water.
  • One participant seeks a formula to calculate the depth of a sinker based on velocity, line length, weight, and water temperature.
  • Another participant notes that drag force is independent of mass and depends on geometry, suggesting that the angle of the tow line should be considered in the calculations.
  • There is a discussion about the effects of the line's mass and drag on the curvature of the line when towing an object, with emphasis on how this curvature impacts the depth attained by the sinker.
  • A participant questions whether the weight being towed is spherical and provides a link to additional resources related to drag calculations.
  • Further elaboration on the relationship between the line's mass, drag, and the frontal area of the weight is presented, highlighting the complexity of the situation.
Participants express varying levels of understanding and confusion regarding the calculations and relationships between the variables involved. There is no consensus on a specific formula or method to determine the depth of the object being towed.
Participants highlight the need to balance forces in both horizontal and vertical directions, but the discussion remains unresolved regarding the specific calculations and assumptions required for accurate depth determination.
Vanselena
Hi, I have been trying to understand the formula for the drag of an object vs the depth of the object in Water. The variables are Velocity, Mass, Weight. Velocity being in Miles per Hour. Mass taken from the cross section of the weight as it moves through the water and the mass of the line used to drag the weight (diameter x length). Weight being comprised of lead ( the line is made of spectra and does not factor into weight ).
Using
Velocity 3 mph
Line length ( diameter being .009" )
Weight 5 ounces
Mass ( line diameter x distance ( weight diameter .5" )
How do I calculate depth given a water temperature of 60 degrees constant.
Here is the closest I have found on the web, unfortunately they do not allow for line diameter of spectra
http://www.geometrics.com/TowDepth.htm
This formula has eluded me and I am hoping someone can help.
I am a new member and this is my first post!
Vanselena
i am cofused! what do you want to know?
the drag force on an object is independent of its mass, it depends on its geometry?
looking at your link, I'm thinking your towing an object through water using a tow line and you wish to know what angle the tow line makes with the horizontal??
you need to balance forces in the horizontal and vertical.
for vertical you'll have weight of the object, the bouyancy, and the vertical component of tension in the tow line
for the horizontal you'll have the horizontal component of the tension in the line, and the drag force working against it!
the drag of an object is .5*density*v^2*Cd*A
density is the density of the fluid your in [water?]
v is its velocity, and A is the FRONTAL area (the area of its shadow would cover)
Cd is a drag coeficient which can be looked up from tables and will depend on the SHAPE of the object.
Hi what I would like to know is a formula to know the depth attained by the sinker given the following variables
Velocity 3 mph
Line length 100 feet ( diameter being .009" )
Lead Sinker being 5 ounces in weight
Is the weight spherical? You'll need this: http://www.cord.edu/faculty/ulnessd/legacy/fall1998/sonja/stokes.htm
I very much appreciate your responses.
The general problem is dragging a towfish through the water doesn't produce a straight angle. the line curves similar to that of the curved line when flying a kite. Initially the weight of the cylindrical object causes a direct angle from the source to the weight. As the line extends further out the mass of the line starts to have an effect and thus produces a curve in the line from the source to the weight. A line that is .01" may seem insignificant however at 100" that line is causing one square inches of mass and at 900 inches of line out there is now 3 square inches of drag. This is what causes the curved shape in the line to the weight being towed.
I am still unsure of the formula to show
line out (causing line mass drag)
and
weight
and
frontal area of the weight (causing weight mass drag)
and
velocity
and
Water temperature of 60degrees
= what depth
Thank you for your responses!
  • · Replies 23 ·
