Rotational Motion - Finding Linear Distance
The discussion focuses on calculating the linear distance traveled by a point on the edge of a 45.0 cm diameter wheel as it accelerates uniformly from 205 rpm to 385 rpm over 7.5 seconds. The key equations used include angular acceleration (a = (w - v) / t) and the relationship between angular displacement (h) and linear distance (s = r * h). The user initially struggled with the conversion of angular displacement from radians to meters but ultimately resolved the issue independently.
  • Understanding of angular motion concepts
  • Familiarity with unit conversions between rpm and rad/s
  • Knowledge of kinematic equations for rotational motion
  • Basic algebra for solving equations
  • Study the conversion of angular velocity from rpm to rad/s
  • Learn about the relationship between angular and linear motion
  • Explore the implications of uniform acceleration in rotational dynamics
  • Practice solving problems involving angular displacement and linear distance
Students in physics or engineering courses, educators teaching rotational dynamics, and anyone interested in understanding the principles of angular motion and its applications.
hana.e.kim
A 45.0 cm diameter wheel accelerates uniformly from 205 rpm to 385 rpm in 7.5 s. How far will a point on the edge of the wheel have traveled in this time?
w=omega
v=initial omega
a=angular acceleration
r=radius
h=theta
t=time
s=distance traveled.
w^2=v^2 + 2ah
a=(w-v)/t
h=s/r
So, I converted 205 rpm and 385 rpm to rad/s. Then I found angular acceleration by using the formula: a=(w-v)/t. Then I plugged everything into the equation: w^2=v^2 + 2ah and solved for h(theta). Then I converted h(theta), which was in radians, to meters by multiplying it by the radius because h(theta)=s/r. Apparently that's the wrong way though, so if anyone could help me out, I'd love him/her forever. Thank you!
Can you show your calculations? It's much easier to track down an error that way.
Actually, I figured out how to do it. Thanks anyway!
  • · Replies 17 ·
  • · Replies 18 ·
