Projectile with friction on an inclined plane
The discussion focuses on analyzing the projectile motion of a 2.0 kg wood block launched up a wooden ramp inclined at a 35-degree angle, with an initial speed of 10 m/s and a kinetic friction coefficient (μk) of 0.20. The calculations reveal that the block reaches a vertical height of 2.04 meters above its starting point. Additionally, the net force acting on the block during its ascent and descent is crucial for determining its speed when sliding back down the ramp.
  • Understanding of Newton's laws of motion
  • Knowledge of projectile motion and kinematics
  • Familiarity with frictional forces and coefficients
  • Ability to resolve forces into components along an inclined plane
  • Study the concept of work-energy principle in mechanics
  • Learn how to calculate forces acting on objects on inclined planes
  • Explore the effects of friction on motion in various scenarios
  • Investigate the use of kinematic equations in solving projectile motion problems
Students in physics, particularly those studying mechanics, as well as educators and anyone interested in understanding the dynamics of objects in motion on inclined surfaces.
kraaaaamos
Projectile motion with friction on an inclined plane -- PLEASE HELP!
A 2.0 kg wood block is launched up a wooden ramp that is inclined at a 35* angle. The block’s initial speed is 10m/s. (Given that μk = 0.20)
a. What vertical height does the block reach above its starting point?
b. What speed does it have when it slides back down to its starting point?
FOR PART A:
I know that initial velocity (y component) is Vi = Vi sin theta
= 10 sin 35
= 5.73m/s
I know we use the equation:
Vf^2 = Vi^2 + 2a (deltaY)
So we need the value of a . . .
Fnet = ma, but we need to knwo the value of Fnet
Fnet = Flaunch - Fk?
We know that Fk = coeff (m)(g)
= 0.2 (2)(-9.8)
= -3.92N
Do we need to find the value of the force of the launch?
I assumed that the value of the launch can be divided into the x-component and the y-component
vi(x) = Vicos theta
= 10 cos 35
= 8.19 m/s
vi(y) = Vi sin theta
= 10 sin 35
= 5.73 m/s
and if we plug in those values to get their overall magnitude
sqrt ( vi(y)^2 + vi(x)^2 )
sqrt [ (8.19)^2 + (5.73)^2 ]
sqrt [ 67.1 + 32.9]
sqrt (100)
= 10
Flaunch = 10 ( mass)
= 10 (2)
= 20N
Fnet = 20 - 3.92
= 16.08
Fnet = ma
16.08 = (2)a
a = 8.04 m/s2
Vf(y)^2 = Vi(y)^2 + 2(ay)(deltaY)
0^2 = 5.73^2 + 2 (-8.04)(deltay)
-32.8 = -16.08 (deltaY)
deltaY = 2.04m <<< FINAL ANSWER...
is that corect? Everything from the point where I suggested that Fnet = Flaunch - Fk . . . was something I deduced on my own. So I have no idea if it even makes sense.
Instead of taking velocity component, take the component of weight along the inclined plane. When the block is going up Fnet = component of weight + Fk. If you want to launch the block up the inclined plane you have to do work against this force. Work done = Fnet X distance moved along the inclined plane. From that you can find the height. When the block is moving down, Fnet = Component of weight -Fk.
While going up work done = loss of KE
While going down work done = gain in KE
It is simpler to resolve velocities and forces parallel and perpendicular to the ramp rather than horizontal and vertical.
Reason: the block moves parallel to the ramp; the normal force (required to calculate the frictional force) is perpendicular to the ramp.
Using this approach I get this expression for the answer to a
[tex]\frac{10^{2}tan35}{2g(sin35 + 0.2cos35}[/tex]
20K
  • · Replies 18 ·
