A real life problem, just for fun
  • Thread starter Thread starter catkin
    Fun Life
The discussion revolves around a phenomenon observed in an "ant channel" with a square cross-section of 20 cm x 20 cm, where surface water movement was noted at a velocity of 3 cm/s. Observers identified a distinct interface between moving and still water, which moved at half the velocity of the surface flow, indicating a discontinuity in water flow. The phenomenon suggests a change in water depth as a potential explanation for the observed behavior.
  • Understanding of fluid dynamics principles
  • Knowledge of surface tension effects in water
  • Familiarity with flow discontinuities
  • Basic observational skills in fluid behavior
  • Research fluid dynamics and flow discontinuities
  • Study surface tension and its effects on water movement
  • Explore methods for measuring water flow velocity
  • Investigate the impact of water depth changes on flow behavior
Students of physics, fluid dynamics researchers, and anyone interested in the behavior of water flow and surface phenomena.
catkin
Around one of our buildings we have an "ant channel" of roughly square cross section (say 20 cm x 20 cm) with fish in it to control the mosquito larvae. The surface of the water carries particles giving a good indication of any surface movement.
Late one afternoon we observed the surface moving relatively quickly (say 3 cm/s). Suspecting a leak we followed the moving surface water and were amazed to find that the moving surface gave way abruptly to a still surface. Watching a little longer we observed that the interface between moving and still areas of the surface was itself moving -- at about half the velocity of the moving surface.
It appeared as if there was a discontinuity in the flow of water.
None.
I think I can explain the phenomenon. If no one gets it, I'll give clues.
Hm. I'm not sure. But can I hazard a guess? There's a change in the depth of the water?
  • · Replies 21 ·
9K
9K
  • · Replies 16 ·
  • · Replies 28 ·
9K
